Old 05-30-2020, 06:17 AM   #1
2016 22' Sport
Knoxville , Tennessee
Black tank odor when fantastic fan is running
Greetings all,
We are very pleased with our '16 22FB except for one small thing, I've noticed that when the fantastic fan is running there's enough "vacuum" in the rig that sewer gas is pulled back through the toilet when its being flushed. This is even with using Happy Camper and/or Geocleaning methods.
I've been thinking that I could install a small fan on the vent stack to pull "vapours" out thereby preventing sewer gas from flowing back through the toilet.
Any suggestions?
Thanks!
mshumer995 is offline   Reply With Quote
Old 05-30-2020, 07:03 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Open a window when fan is running.
Try turning off the fan when flushing the toilet.
Old 05-30-2020, 08:00 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Flush while your sitting on it...
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"My sex life is like a Ferrari...I don't have a Ferrari."
Dino Longuini
Tahawus....🌥
ROBERT CROSS is online now   Reply With Quote
Old 05-31-2020, 11:15 AM   #4
2016 22' Sport
Thanks for observations. Open window is probably the best. I did find the Stank Stack but too complicated. Cheers
Old 06-06-2020, 07:19 PM   #5
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
Your Fantastic Fan is probably not the problem. Unless you have not followed directions about having a WINDOW open when using the FAN.
Your toilet, after using, opens the slide that drops the goods and the small amount of water down the hatch.
If your sliding seal is not holding water... blame it, not the Fantastic Fan. I doubt if the Fan has Super Powers, mine does not.
Pour some water into the stool... if it drains right away... fix that. If it drains slowly to nothing... same problem. It is leaking water past the sliding gasket that is suppose to hold the water and SEAL the Black Tank gases from entering the interior of your trailer.
The minor weight of the water keeps any vapors from entering the interior of the trailer.
If it holds water and still is noticed. Check the large vent pipe covered by some white thin plywood in an outside corner IN the bathroom. It goes from the floor to the ceiling. Easy to find. Remove the few wood screws and... sniff around.
If this also does not solve the problem, as well. Take a hose, flush the black tank from the inside the trailer, after each trip. Use the Service Station rest rooms as often as possible.
I have other suggestions, but my humor may... stink, as well. Good hunting.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-14-2020, 09:22 AM   #6
2010 25' FB Flying Cloud
mcminnville , Oregon
check toilet flange
I have had the problem for five years of a smelling bathroom. Yesterday i took a very close smell around the toilet base and the odor was awful. I took the toilet off and found small gaps in the floor and the toilet flange. Where the two bolt came up to secure the toilet i could see into the tank. Two other bolt holes had gaps in the plate and floor, chalked them all really well. Just slid the bolts back into the chalked slot. Problem solved. Really cant believe it was installed that way or that it took me so long to find it.
pal50 is offline   Reply With Quote
Old 06-29-2020, 08:01 PM   #7
Ray Eklund's Avatar
Originally Posted by mshumer995 View Post
Greetings all,
Any suggestions?
Thanks!
Our toilet did the same after this last trip. The rubber on the bottom side appears to deteriorate and is obvious if you take a paper towel and rub the bottom. It will leave black rubber pieces.
I thought I could clean the surface to fix the problem. Could not. The bottom of the rubber seal was not sealing as designed.
The top part appears just fine.
We noticed on this trip the water would seep out. I added a glass of water into the stool... the same. You could hear it drain and made a noise... believe it or not. The local Airstream Dealer said they have the parts on hand and we take it in next month.
Human Bean
Old 06-30-2020, 08:21 AM   #8
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
If the toilet is not sealing, the problem is probably the black rubber piece of the valve. My wife changed ours out and said the job was not too hard. The replacement part should be easy to obtain.
SSquared is offline   Reply With Quote
Old 06-30-2020, 06:44 PM   #9
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Hi
My RR is in the back, my Fantastic fan is in the front, if the fan is in exhaust mode it creates a negative pressure in the trailer drawing everything (smells) into the trailer. A simple solution is to reverse the Fantastic fan and pressurize the trailer instead, your still bringing in cooler outside air from the (fresher) end of the trailer. I close my RR door (it has a bottom gap) and open the little RR fan (don't need to turn it on). So the fresh air comes into the Fantastic fan, into the trailer, across the length of the trailer, under the RR door, up thru the RR, up and out the RR vent, works great, RR smells are pushed outside and not drawn into the trailer. I never use my Fantastic fan in exhaust mode, always in supply mode, what you are after is air-changes, its just a different way of thinking about it.
Happy Travels!
2003 Safari 25SS
Ahroc is offline   Reply With Quote
Old 07-01-2020, 07:08 AM   #10
2016 22' Sport
Thanks Ahroc, that's the best suggestion yet.
Converter fan running... batteries fried... batteries replaced... fan still running! hollycwright Batteries, Univolts, Converters & Inverters 2 04-27-2020 03:41 PM
Fantastic fan and odor clicker187 Waste Systems, Tanks & Totes 41 03-06-2016 09:29 PM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
black tank odor filled trailer HELP arcamedies Plumbing - Systems & Fixtures 18 06-11-2012 08:55 PM
Controlling Black Tank odor thecatsandi Waste Systems, Tanks & Totes 36 05-03-2012 06:49 AM
