Old 02-22-2020, 06:30 PM   #1
stream19's Avatar
2015 19' International
East Woodstock , Connecticut
Black Tank leaking
I just noticed that my 2015 19’ International has a small leak from I’m guessing my black water tank. As I emptied I noticed drops of water falling from the under side of the trailer appx. 10” to the right of the black water valve. The bottom of the trailer is sealed with sheet metal and plastic, so it is difficult to see exactly where the water is coming from. When I empty the black tank the leak appears to stop. Is the black tank above the plywood floor? Will this leak damage plywood or other components until it fixed. Is this an Airstream dealer only repair? It appears that the bottom of the trailer will need to be opened. Thanks for any advice.
stream19 is offline   Reply With Quote
Old 02-22-2020, 07:37 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Tank is below the floor. Dropping the bellypan involves filling out some rivets. It’s not hard but if you are not comfortable with basic tools or feel you could fix the tank if you found the problem it’s best to seek professional help.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 02-22-2020, 09:17 PM   #3
"Cloudsplitter"
We had a leak in the grey tank valve, squoze out of shape right from the beginning. Cut a large access hole in the bellypan to change it out. This was a few years ago...not sure I'd start it again now-a-days...
ID:	361650   Click image for larger version
ROBERT CROSS is online now   Reply With Quote
Old 02-22-2020, 09:35 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Put water and two different colors of food coloring in each tank. Catch the drip and see what color it is.
CRH is offline   Reply With Quote
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 10:20 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Black tank leaking bimpy Waste Systems, Tanks & Totes 1 08-13-2009 01:24 AM
Leaking Black Water Tank ssolid Waste Systems, Tanks & Totes 6 04-10-2009 07:26 PM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
