Old 11-01-2024, 02:11 PM   #1
2004 28' Safari S/O
Buhl , Idaho
Black Tank Handle Repair?
So my black tank handle broke off and this is what’s left. Is this an easy fix? My black tank valve is getting harder to open, so when I went to open it, BAM it smashed to bits. Thank you guys for any advice!
Dehonian is offline   Reply With Quote
Old 11-01-2024, 06:15 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
If the threads on the end of the rod are not damaged, you could screw another T handle on. If you want to replace the handle and rod as an assembly, you will need an access hole in your belly pan because you have to drill out a rivet that attaches the handle rod to the dump valve, then rivet the new one in place.
Given the age of your trailer and the fact the dump valve is hard to open, it may be time to consider replacing or rebuilding your dump valves.
CRH is offline   Reply With Quote
Old 11-02-2024, 12:35 AM   #3
2004 28' Safari S/O
Buhl , Idaho
What would the size needed for a replacement handle be? The threads seem okay!
Old 11-02-2024, 06:54 AM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
This should be what you need.
Name:	Screenshot_20241102_074933_Samsung Internet.jpg
Old 11-02-2024, 10:15 AM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
I purchased an aluminum Valtera handle and a ¼" x20 4" stainless steel bolt (which was cut to length) for my gray water tank. There is also a black metal handle for the black water tank in this section of the web site.
https://www.amazon.com/Valterra-T100...14&sr=8-1&th=1
These are not subject to breaking.
New Black Tank thinking about adding a black tank flush Peter417 Waste Systems, Tanks & Totes 1 12-21-2020 11:18 AM
Black tank pull handle screw head broke off underneath and can’t empty tank. HabitatGuy Classic Motorhomes 18 06-21-2020 08:35 PM
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 11:20 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
Black tank handle Bing-Bing Waste Systems, Tanks & Totes 16 03-27-2014 02:51 AM
