Old 06-18-2025, 07:26 PM   #1
2020 30' Flying Cloud
Northern , Illinois
Black/Grey Tank Professionally Cleaned, is it worth it?
If you have had your black/grey tanks cleaned professionally, is it worth the cost? We purchased a 2020 Flying Cloud recently and are considering having the tanks cleaned. We just don't know if it's necessary or worth the $300. What are your experiences?
run2smile is offline   Reply With Quote
Old 06-19-2025, 05:43 AM   #2
2020 28' International
Wilmington , North Carolina
It wouldn't be worth the cost. I'd suggest using a Walex Commando tablet, filling the blank tank at least 50% full with water, and then taking a camping trip at least 100 miles from your house to give the tank a "shake and bake". In my experience, these tablets do a wonderful job.
Name:	Screenshot 2025-06-19 at 7.41.34 AM.png
etojeo is offline   Reply With Quote
Old 06-19-2025, 06:09 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Images: 8
After emptying/rinsing my Airstream's tank, I fill it with water and a cup of Clorox, then empty that. The tank has no appreciable odor between trips.
TomW
Old 06-19-2025, 08:12 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I had it done a long while ago. Far enough back so that it cost $200. I did it before taking the valves out for replacement. I thought it was worth it for that function. And the trailer I did it too had been used without moving for a number of years. Probably not necessary but there are probably worse ways to spend the $300 too if getting the tanks cleaned gives you peace of mind.
Old 06-19-2025, 08:55 AM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I don't see the need unless a trailer had years of improper tank use.
I replaced both my tank valves when my trailer was just over 20 years old. I peeked in the opening of both tanks from the bottom. They were clean. A few years later, I was replacing the toilet and dropped a flashlight in the black tank. I scratched around bicep deep in the tank for a good while trying to get the flashlight. My hands came out clean.
CRH is offline   Reply With Quote
Old 06-19-2025, 09:10 AM   #6
2019 30' Classic
Hillsboro , Texas
Does it clean them? Yes. Does it help with smells that are hard to get out another way (mild or mildew)? Yes. Big difference in my 2005 that had never had it done.
Isn’t worth it? Value is in the eye of the beholder. Some people don’t use diesel additives. Some people do and wouldn’t fill a tank without it. Some people cut their own hair, others need professional pedicures.
If you have a problem you want to solve, it might be part of your solution. If you are the kind of person who likes to do whatever it takes to keep their rig in tip top shape, this might be part of your routine when you put it away for the winter. Value is onto you to decide.
2019 Classic and 2005 Land Yacht 396 XL and 2 cats
Certified RV Tech, LP certified in TX, generator certified and Alde certified.
LilPeanut is offline   Reply With Quote
Old 06-19-2025, 09:36 AM   #7
2015 30' International
Escondido , CA
Black Fly
We removed our toilet three years ago and installed a composting toilet, so we use both tanks for gray water. Recently we had our tanks cleaned for the first time on our 2015 30RB. The technician said we had lots of crystals coming out and explained the situation below as a likely outcome.
A common issue in RV grey tanks: a combination of mineral buildup (often called struvite) and a drain fly infestation.
Causes:
Struvite buildup: This crystalline substance forms from magnesium, ammonia, and phosphate and can coat tank walls, clog valves, and cause sensors to malfunction.
Drain Flies: These flies are attracted to and breed in moist organic waste, like the debris and slimy film that can accumulate in drains and holding tanks.
dsatwork is offline   Reply With Quote
Old 06-19-2025, 10:18 AM   #8
nadrad314's Avatar
2021 27' International
Glens Falls , NY
I was struck by the word, "professionally". I'm sorry, but the people I've had the luck (misfortune) to get to work on my trailer (and house for that matter) always leave a bad taste in my mouth. So many times I've had to do the work over again myself, or clean up after them, that is not worth the money to hire them!
Believe me, I'd happily pay someone to do the work for me, IF THEY WOULD DO A professional job. Then, around here, you have to schedule the work out 6-10 weeks and always drop your trailer off for a week, after which they will tell you they need to order the parts, then after another two weeks they tell you the wrong part came in.... etc.
So now, I pretty much do everything myself.
Jon Nadler
Upstate New York
27' International FB
TV: F-250, 7.3L Gas Engine
nadrad314 is offline   Reply With Quote
Old 06-19-2025, 11:58 AM   #9
2019 28' Flying Cloud
Broward , Florida
Professional cleaning is not necessary. The Airstteam manual tells you how to disinfect the tanks with a bleach solution. Whe it comes to sanitation, bleach is man's best friend.
Andy543 is offline   Reply With Quote
Old 06-19-2025, 12:00 PM   #10
2019 22' Sport
High River , Alberta
It doesn’t seem worth the money to me, unless you have a constant odour issue or plan to have the valves replaced.
We’ve never used any kind of product in our waste tanks, and we rarely smell anything. Of course, we live in a cooler climate, but I think normal use shouldn’t create problems. Towing some distance to a dump station seems to help stir everything up and avoid clogs.
AlbertF is offline   Reply With Quote
Old 06-19-2025, 08:49 PM   #11
Anna Maria , Florida
Not to me it wouldn't be.
I never empty a partialy filled black tank. I always fill the tank completley before dumping .
Afterwards I throw in cleaner deodorizer with 5gl. water.
No odor problems.
franklyfrank is offline   Reply With Quote
Old 06-29-2025, 09:13 AM   #12
1963tradewin's Avatar
1963 19' Globetrotter
1963 22' Flying Cloud
1963 24' Tradewind
, , Minnesota
No, its not worth it. Buy yourself a box of calgone in a box with a small bottle of pinesol at Walmart. Dump the 32 ounces down your toilet, then add 5 gallons of water. Drive to your campsite. We drove approximately 3 hours letting that stuff slosh around. Got to the site, dumped it out. Major crud comes out. Flush with a full tank. Now you have a clean tank, and it's deodorized. Learned this trick from an old timer years ago. Will cost you around 10 bucks.
1963tradewin is offline   Reply With Quote
Old 06-29-2025, 09:56 AM   #13
1963 24' Tradewind
, , Minnesota
Fresh water tank cleaning
For fresh water tank, do this.
Old 06-29-2025, 10:28 AM   #14
1985 31' Excella
st. Paul , mn
I have been living full time in MN , through the winters also .
Haven't been able to be on the road for over 20yrs.
In that time I had the tank plug up once after winter was over .
So what I came up with was having some 1/4 copper tubing [ tubing is bendable / pipe is not ] - I put as large of an arc in the tubing as possible - to be able to get through the toilet and into the tank - the length is to feel for the drain opening .
Once finding the opening - poke the plug of sludge to drain tank .
Now with this same copper tubing [ but I made another tool out of PEX with a 90 deg. elbow and a 1/4 turn valve , with a adapter for garden hose - all about 4' long ] the copper also need right angle into tank - from toilet and hose adapter & valve .
Now with between at least a couple inches in tank , move the - NEW FLUSH TOOL , up and down and also spin around to cover all of tank .
To help keep messing up , I hold the foot valve of toilet open just enough to not bind on tool , then also use like the small plastic shopping bags in toilet above foot-valve [ to help keep any splashing coming out ] .
Major cost is hose , valve
I did have one of those back-flush clear plastic - connect at dump outside - I will never use it - but not throwing away either .
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 06-29-2025, 01:54 PM   #15
2022 23' Flying Cloud
Watsontown , Pennsylvania
Just had the first instance of the black tank smelling really bad. Not sure if it was build up or what. Took some advice from this forum and filled tank halfway with water, some dawn, some odoban soap sanitizer and some bleach. Let it slosh around.
Then drained it and used the black flush for a long time.
Tank water is (for now) clear and clean and there is no odor whatsoever and looking into tank with flashlight, it appears spotless.
ricjones is offline   Reply With Quote
Old 06-29-2025, 06:29 PM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Hahaha! April 1 already?
Have them change the air in the tires too!
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 06-29-2025, 07:01 PM   #17
San Jose , California
I never clean my tanks— just empty the black first followed by the grey. We don’t put any paper down the toilet. I use my rig about once a month so nothing is sitting too long. We also don’t drink our fresh water — we pack water. Going on year 5.
BHChieftain is offline   Reply With Quote
Old 06-30-2025, 09:17 AM   #18
2021 25' Globetrotter
Hickory , North Carolina
Clean Black & Grey Tanks
Yes‼️
SoupStream is offline   Reply With Quote
Old 06-30-2025, 10:23 AM   #19
2019 25' Flying Cloud
Sequim , Washington
My sentiments, experience and practice, too!
WestieHouse is offline   Reply With Quote
Old 07-01-2025, 08:06 AM   #20
Redbarron55's Avatar
1985 25' Sovereign
Navarre , FL
I bought a 3" curved drain fitting with a flush tap that I drilled out to 5/8" so that a small diameter pressure wash hose would go through. (I had to build up the area where I cut through the plastic with some epoxy, but it works).
I bought a drain cleaning kit from an Amazon seller and a $20 electric pressure washer to complete the setup.
With this I can non=professionally pressure wash my tanks.
It is handy to get a shut off valve on the end of the hose next to the pressure washer so you can completely shut off the dribble with the pump off.
The drain cleaner kit came with several cleaning heads to run into the tanks and one that has a bearing and a more powerful spinning action that blows more water in a stream that may clean better.
The drain cleaning kit was about $30.00 as was the clean-out fitting.
I left the hose fitting on the drain fitting so that I could put a plug on it and use it for a strain relief for normal use.
The "local" cleaning Professionals offered a deal at $250 so I think I came out fairly good and can clean anytime I think it needs it.
I still have to work on the technique as the black sensors on my 1985 seem to be in a difficult to clean spot and need a retreatment it would seem.
Redbarron55 is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Having your TT professionally hauled Spirit General Repair Forum 5 08-31-2012 08:55 AM
1962 AIRSTREAM GLOBE TROTTER Professionally Restored eBay Watch Airstreams on eBay 0 07-18-2012 02:50 PM
1967 Airstream International 30' Travel Trailer - professionally restored eBay Watch Airstreams on eBay 0 06-25-2012 10:20 AM
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
