Old 09-06-2024, 06:06 AM   #21
Nashua , New Hampshire
Originally Posted by JBTeton View Post
Interesting chemistry mix. The baking soda and citric acid will cancel each other out and form sodium citrate, CO2, and water. This should make for basically a fizzy mix. The Borax is probably doing most of the cleaning and deodorizing in this mixture. Borax is a strong disinfectant and will likely reduce the "good" bacteria in the tank.
Yes, it does foam somewhat when added to water, which as you said is expected when you combine an acid and a base. I can't find any reference to borax being a disinfectant - though it is marketed as a deodorizer - and this combination is supposed to support the good bacteria in the tank, not kill it. Rather than combining the ingredients into "bombs", I prefer to keep them separate and mix them when I add them.
Regardless, it does seem to work at touted and we don't have any odor issues.
Bnystrom is offline   Reply With Quote
Old 09-06-2024, 07:42 AM   #22
billrector's Avatar
2017 27' Flying Cloud
Fort Worth , Texas
Originally Posted by waninae39 View Post
after we use this solution
we place a bag of ice in the black tank
this scrubs the tank clean also
There are YouTube videos that debunk this procedure.
billrector is offline   Reply With Quote
Old 09-06-2024, 12:09 PM   #23
nelsonh's Avatar
2023 23' Flying Cloud
Carroll , Iowa
Originally Posted by SpikePoet View Post
Is this any better/different than simply treating your black and gray tanks with Happy Camper and water after each tank dump?
Spike
I would say different and not necessarily better. This mixture is mainly a deodorizer and tank surface slippery-ifier; Happier Camper is engineered it actually break down solid waste within the tanks. Two different products with two different intended purposes...and I tend to use both, FWIW. But I'm still quite new at this and don't have much personal real world long term evidence that either or both are doing what they claim to do....
2023 Flying Cloud 23FBT ~ 2024 Ford F150 XLT PowerBoost 7.2 kw ~ 2010 Border Terrier
nelsonh is offline   Reply With Quote
Old 09-06-2024, 12:22 PM   #24
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
TankTechsRX is another enzymatic solution. I have been using it for years now and have had no odor since I started unless I went too long without using the trailer and the tank dried out. If so, the odor went away immediately after adding some water and another dose of TankTechsRX. I have, on occasion, used it in the gray tank as well.
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 09-07-2024, 09:44 AM   #25
Jame at thefitrv.com did a really thorough test of this and the bottom line is that it's a waste of time and ice.
Old 09-07-2024, 10:06 AM   #26
JBTeton
JBTeton's Avatar
Boulder , CO
"Borax, or otherwise known as sodium borate, is a natural mineral mined from the Earth that is most commonly found as a white powder. It’s most notably characterized as being a good emulsifier, preservative, and buffering agent (2). It’s also known for being a great disinfectant, getting rid of stains, whitening clothes, and neutralizing hard water (2, 3). Because of these properties Borax is often found in common household products like laundry detergents, soaps, and degreasers. It’s also found in topical medicine, food preservatives, pesticides, and other industrial uses because Borax can inhibit the growth of bacteria and mold, increase resistance to heat and chemicals, kill insects, and helps balance acidity (4)."
https://ceh.org/yourhealth/how-safe-...d%20degreasers.
Pretty much every google search on "borax disinfectant" confirms its anti-microbial properties. That said, and given the amount of bacteria in the tanks, a little borax probably won't hurt too bad.
JBTeton is offline   Reply With Quote
Old 09-07-2024, 01:53 PM   #27
DaveG's Avatar
Here and There , West Coast
"Borax can inhibit the growth of bacteria and mold"
"Bacteria and enzymes are a very good thing in your RV holding tanks because they reduce the size of waste so it flows out better during dumps and remains under the water while being stored in the holding tanks, thus getting rid of holding tank odors."
DaveG is offline   Reply With Quote
Old 09-08-2024, 07:51 AM   #28
JBTenon, thanks for pointing this out. Somehow I missed it, though as you said, it may not do any harm. The treatment method definitely works, so that seems to be the case.
Old 09-08-2024, 02:20 PM   #29
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
You don't want to use bleach in black and gray tanks, as you don't want to kill the beneficial bacteria that break down the contents.
What bennificial bacteria you talking about?? Really...think about it; you empty your tank, and flush thru black water port, right? (least many of us do.) Then you add which ever "additive" you are using...not bacteria based. If it was, the smell would surely require emptying more than once a week or so when in use!
I stay in a 5th wheel all summer here in WY where it gets 80-90 each day. Have to dump every 5 days or so, the black tank. (My Airstream is kept in storage, but we do service our tanks prior with cleanout.) Anyway, just talked to a guy here, who has been doing the "clean tank" cleanout business for many years, who also lives in Houston in winter. He is coming to clean out our black/gray tanks on this 5th wheel, and also our black/gray tanks on the AS which give "erroneous" readings after 7 years of using. Anyway, he said he fixes the readings on 95% of the customers with his method, which includes high pressure hose/tank washing.
For the servicing, he said: 40oz Pine-Sol with 8oz Calgon Ageless Bath Pearls in gallon jug. Top off with enough water to fill. Shake gently, and allow foam to die down. Then apply 4-8 oz in each tank to maintain clean tank. The Calgon keeps the "sludge" from collecting on the sides and valves; "commercial" tank remidies, do not...they treat the waste, but do not coat the sides like the Calgon type water softeners do. I have talked with several folks who have been using this method and they say it works! (at the pickelball court here in WY, where we all play over the summer, and they swore by this guy!)
2017 28' Twin Flying Cloud
Old 09-21-2024, 01:12 PM   #30
2023 19' Caravel
Encinitas , California
I have another black/grey question. When hooked up to a campsite waste hookup, do you leave the airstream tank open to the hookup? or let the tank collect waste then empty once a day or...?
Billrdean is offline   Reply With Quote
Old 09-21-2024, 01:56 PM   #31
Bearstream01's Avatar
2023 25' International
Long Island , New York
Hi Bill. Welcome to the forum. I answered you in a private message.
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
Bearstream01 is offline   Reply With Quote
Old 09-21-2024, 04:59 PM   #32
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Black tank should always be closed until you dump. You would be best to wait until the black tank is half full or more before dumping to get a good flow out the discharge opening.
Gray tank could be left open, but we never do. Leaving the valve open allows flies/gnats to enter the tank and doesn't leave you with enough gray water to flush out the sewer hose after you dump the black tank.
We operate the tanks like we're always dry camping, only opening the valves when we dump. We connect the hose right away for convenience but leave the valves closed on the trailer.
The gray tank fills first. When it fills we do the following:
  • Dump the black tank, then close the black tank valve. (If you were going to use your black tank flush you'd do it before closing the valve - we don't have a working flush anymore so we skip this).
  • Dump the gray tank, which flushes out the sewer hose, then close the gray tank valve again.
  • Wait until the
    gray tank needs to be dumped, and then repeat the process.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 09-22-2024, 09:06 AM   #33
gypsydad's Avatar
Never leave your black tank valve open. Instructions in your AS manual, on this, by the way. We dump when it gets "full". Gray tank will fill before black, so you may have to dump gray 2-3 times before your gray fills. But, procedure is dump the black first, also using a hose connected to the black cleanout connection which helps flush out as your dumping. We use a clear elbow on the hose so we can monitor the black water, and I look for clear water coming out from the hose. Then shut off the hose, and close the valve; then I open the gray valve to help flush hose as its draining. When all finished dumping, I close the gray valve and rinse everything. Easy, peasy. Don't forget to add which ever chemical you like to the black tank...we forgot in Florida one year...was embarrassing when we finally reached our destination at a friends house, and he wanted to see our AS...wow! forgot to add the solution!
Old 09-22-2024, 10:18 AM   #34
2023 19' Caravel
Thanks for the help/advice/response. New to airstreaming, loving it while learning and figuring out. Now onto shopping for Calgon Beads.
Old 09-22-2024, 12:29 PM   #35
gypsydad's Avatar
Yea, that can be challenging depending on where you are! Pinsole not so much of a challange, but Calgon seems to be. He recommended Walmart, but that's 80 miles away and local grocery stores here not carrying that, so I ordered 3 pack of Calgon on Amazon. Wife made up the big bottle using the recipe and then transferred to smaller bottle for travel.
Name:	Tank treatment.jpg
Old 09-22-2024, 04:52 PM   #36
nelsonh's Avatar
Carroll , Iowa
A tip I picked up on YouTube that I've adopted is to get the dump hose all hooked up and then open the gray tank briefly first to check for any leaks... the idea being it's less gross to deal with any leak in the hose or fittings when it's gray water leaking out vs black tank water.
Old 09-23-2024, 09:36 AM   #37
gypsydad's Avatar
Never had an issue with the sewer hose leaking....not saying it can't happen...but if you take care of your hose, and clean it out by running water thru it after each use before stuffing back in the holder behind the dump station valves, think you will be fine.
Old 09-23-2024, 11:48 AM   #38
nelsonh's Avatar
Carroll , Iowa
I did once have a hose that was punctured and I didn't know it which leaked some black water. But yeah, in my case it's more like "didn't get all of the twist-fitting-connections properly twisted on" that results in a leak, more than the actual hose itself... although I'm getting better this as time goes on!
Sanitizing Potable Water tank pond Winterizing, Storage, Carports & Covers 20 04-30-2015 09:17 PM
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 12:07 PM
Sanitizing the water system zimbop Fresh Water Systems 13 02-11-2013 09:36 AM
Sanitizing Water System bike_addict LP Gas, Piping, Tanks & Regulators 27 10-12-2011 05:47 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 11:23 AM
