Old 06-10-2022, 06:14 PM   #1
2022 30' Flying Cloud
DFW , Texas
Belly Pan Leak
When I was dumping, I noticed a leak from the belly near the waste outlet. I ran a scope into the pan and as far as I can tell, the leak is coming from one of the fittings between the tank and the outlet. Does anyone have any suggestions for how to fix it without dropping the whole pan?
hawkspur is offline   Reply With Quote
Old 06-10-2022, 06:29 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Cut a hole in the pan, then put on a cover plate. That is how my genuine AS owners manual says to service the dump valves.
CRH is offline   Reply With Quote
Old 06-10-2022, 07:05 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Well, with your new Airstream I would consider letting the dealer repair the leak under warranty. I find it difficult to understand why Airstream did not provide an access panel to service the dump valves when we all know they can be troublesome.
My 1986 Limited had a removable housing around the dump valves allowing me access to replace them. But I did have to unbolt the tank pan to gain full access to the tank connections.
David
Name:	1408 Ground Clearance 86 (Small).jpg
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 06-11-2022, 07:28 AM   #4
DFW , Texas
David
We're full timers and the last time I left my old Nest with a dealer for warranty work on a leak, it took 4 months - unfortunately, warranty work isn't really an option unless it's something catastrophic or expensive
Old 06-11-2022, 08:31 AM   #5
"Cloudsplitter"
Yes...I do'd it that way.
On ours the factory overtightened a flange clamp, it gave up & cracked...dripdripdrip.
ID:	417357   Click image for larger version
ID:	417359   Click image for larger version
Tuck the side belly wrap under the flat belly pan or the other way around? haaseome Belly Pans & Banana Wraps 4 08-24-2021 11:34 AM
Belly pan leak after black tank rinse brendakerry Waste Systems, Tanks & Totes 15 10-06-2020 12:01 PM
Belly pan leak after using macerator pump jaodco71 Waste Systems, Tanks & Totes 0 08-19-2019 03:51 PM
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Leak in Belly Pan sandlubber Forum Admin, News and Member Account Info 1 06-08-2015 02:44 PM
