Old 04-23-2023, 12:58 PM   #1
2008 27' Safari FB SE
2023 28' Pottery Barn
Delta , BC
Bathroom sink emptying into main( black) tank
On my first trip in the trailer and I noticed my black tank is filling faster than my grey tank. Been here for 2 days and my black is now at 60%, and barely used. I also noticed ( from the monitor) that the % increased when I used the bathroom sink? At first I thought maybe sensors were reversed but when i run the kitchen sink the grey did increase. Thoughts?
bugman3 is offline   Reply With Quote
Old 04-23-2023, 01:33 PM   #2
2021 30' Globetrotter
East Northport , New York
The bathroom sink does drain into the black tank on some floorplans. I know it does on my 30RB.
James
Biker is offline   Reply With Quote
Old 04-23-2023, 04:30 PM   #3
2023 27' Globetrotter
Winder , Georgia
I believe in all RB floor plans, the bathroom sink drains to the black tanks. It did on my 25RB. My new FB it does not. Both sinks drain to the Gray. I a RB, If not on full sewer hookups you really have to watch that bathroom sink usage. Maybe even hand washing , teeth brushing , etc all done in kitchen sink.
Bcc75 is offline   Reply With Quote
Old 04-23-2023, 06:45 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
I think it is good design to have our bath vanity sink drain into the black tank. This provides better utilization of the waste water tanks. And you have the added benefit of keeping the black tank wet which helps prevent "mounding" and aids good drainage. Besides, the bath vanity sink is usually close to the black tank so it saves some drain plumbing.
I've renovated 4 vintage Airstreams and in each case I drained the bath vanity sink into the black tank.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 04-23-2023, 06:57 PM   #5
nswhite's Avatar
2022 30' Flying Cloud
Phoenix , Arizona
Our 30RB also drains into the black tank. Initially, I didnít like it. However, it helps with emptying the black tank by having more liquid for dumping. We now like it. We are still able to boondock for 5 days, which is all we need.
nswhite is offline   Reply With Quote
Old 04-24-2023, 08:41 AM   #6
Delta , BC
Good to know, I guess all RB units are similar, I wish the owners manual also told me that so I didnít have to be concerned.
Old 04-24-2023, 10:14 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Our 1994 25-ft has the bathroom sink draining into the black tank. If we're dry camping or not on full hookups we'll just use the kitchen sink instead for most of the usual bathroom washing to avoid filling the black tank.
It was explained to me that this was done to ensure adequate water in the black tank for a complete dump when the black tank is dumped.
Richard
11018
richard5933 is offline   Reply With Quote
Old 04-24-2023, 12:10 PM   #8
2019 23' International
Tomball , Texas
It is shown in the plumbing diagram.
B17drvr is offline   Reply With Quote
Old 04-24-2023, 12:46 PM   #9
2012 23' FB International
Woodstock , Ontario
We routinely dump dish water down the toilet to conserve grey water space. For us the bathroom sink into black water also makes sense
JCW
JCWDCW is offline   Reply With Quote
Old 04-24-2023, 02:26 PM   #10
Delta , BC
Now that I understand that, I need to figure out why it showed 98% filled after light use and when I emptied it this morning, it had hardly anything in it. Maybe the sensor is defective? Not sure how to gauge that.
Old 04-24-2023, 04:13 PM   #11
Napa , California
Traditionally, black tanks fill more slowly than the gray tanks, and for successful emptying the black tank should be as full as possible.
Therefore it is actually HELPFUL to have the bathroom sink empty into the gray tank.
Atwebs is offline   Reply With Quote
Old 04-24-2023, 07:44 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You may have a dirty sensor in the tank possibly toward the bottom of the tank giving you a "full" reading when it is not. Try cleaning your tank. You can search here on these Forums for some different processes to clean the tank.
One method involves half filling the black tank and then dump a couple sacks of ice cubes into the tank. Also include a healthy squirt of Dawn dish soap. You are already hitched up and now tow the trailer for maybe 20 minutes and let the ice abrade and the soap clean the walls of the tank. Now drain the back tank and put some water in it and see what the readout is saying. You might get lucky.
David
Old 04-25-2023, 09:42 AM   #13
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Our 2015 23D bath sink also drains into black tank.
Old 04-25-2023, 07:04 PM   #14
dznf0g's Avatar
Oswego , Illinois
I wish mine did. We can go 2 weeks on black and one week on gray. I'd rather have that be 11 days with both.
-Rich-
Old 04-25-2023, 08:12 PM   #15
2022 27' Globetrotter
DALLAS , TX
JCW
Ditto. We do the same thing. The detergent in the dishwater doesn't hurt when try to keep the black tank clean either.
This helps balance out the amount of water in the black vs grey tanks as well. Helps when boondocking.
Side note: we always fill up the black tank using the black water flush system before dumping the black tank. Subsequently, it usually takes 2 additional full black tank flushes before the water being dumped is fairly pristine (relatively speaking, of course)
foobar is offline   Reply With Quote
Old 04-30-2023, 01:26 PM   #16
2019 25' Flying Cloud
Sequim , Washington
David
For a good illustration of the benefits & limitations of the ice cube approach see this You Tube:
https://youtu.be/iH6acEmqvcw
WestieHouse is offline   Reply With Quote
Old 08-21-2023, 08:32 AM   #17
2023 20' Basecamp
Calgary , Alberta
Last year, I exchanged my RV, including my prior 25RB. The black tank receives drainage from the bathroom sink. In contrast, both sinks in your new FB model drain into the grey tank. This explains why, while using the bathroom sink, you saw a rise in the black tank's level. Doing things like brushing your teeth and washing your hands at the portable sink will free up room in the grey tank and help you manage tank levels more effectively, especially if you have a partial sewer hookup. Hope this was helpful.
alex778 is offline   Reply With Quote
Black Tank Valve Stuck in ON. Tank not emptying. eyechip Sprinter and B-van Forum 3 09-25-2018 11:07 PM
Emptying Black Waste Tank helluva Waste Systems, Tanks & Totes 13 07-01-2016 09:26 PM
2015 flying cloud 30 bathroom sink drains into black tank Aggie90 Waste Systems, Tanks & Totes 10 10-18-2015 06:34 AM
25 Foot 2014 FC steps for flushing and emptying black water tank DogGonnit Airstream Trailer Forums 5 09-15-2014 06:28 PM
First emptying of the black tank Getahobby Waste Systems, Tanks & Totes 8 08-08-2012 12:32 PM
