Originally Posted by nickknack
Lots of good information, but the audience seems split. After calling the blue and orange stores for special order, I don't need enough for them to do it. Even Plumbers Supply didn't have it on hand. I'm going with PVC, but will have a mechanical connection for where the PVC meets the tank. Thanks for the advice!
Old construction guy here. I would stick with one kind of material, one kind of glue. IMO, ABS is the better choice for a travel trailer.
I have successfully used combinations of ABS and PVC pipe and fittings. I've also seen it fail, specifically the glue joints fail.
Try your local mobile home parts store. I've had luck at Mobile Home Depot (local where I am in FL) finding 3", 2" and 1.5" ABS pipes and fittings. They may ship if you call them.
If the mobile home parts store does not work, you can order online at HD and have it delivered to your house or HD local store.
fittings>
https://www.homedepot.com/s/abs%2520...ittings?NCNI-5
pipe>
https://www.homedepot.com/s/abs%2520pipe?NCNI-5
