Old 06-10-2018, 08:48 AM   #1
1966 22' Safari
Cedar Rapids , Iowa
'66 Safari rear dump fittings
Hello all,
The dump valve is trashed(thankfully I've located replacement) and badly rusted bolts kept me from getting it off without cutting Y off at 2" elbow. This dump Y has about a 10 degree offset angle to it where mounts to valve and I'm not finding this part available anywhere. Any ideas? Maybe I can attempt to remove cut off 2" elbow, clean up and reuse but no guarantees that it won't break in process. Additionally, the glued to tank "mounting" bracket where badly rusted bolts were, split the mounting holes. Thinking of filling with epoxy, clamping then re-drilling. Any thoughts here as well? Thanks for any and all help here! Greg
ID:	313616   Click image for larger version
mysilverbullet is offline   Reply With Quote
Thoughts on moving the dump fittings on the outside of our 64 Ambassador gomotomoto Vintage Kin 1 04-09-2018 07:39 AM
Copper compression fittings vs. flare fittings MR AIRSTREAM LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Rear bumper / hose fittings Hoosierdaddy Bumpers & Bumper Storage 1 07-04-2011 08:47 PM
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 06:58 PM
