Old 04-11-2018, 05:08 AM   #1
Crested Butte , Colorado
2 grey vents?
My 1974 Sovereign has 3 plumbing vents on the roof. 1 for the black tank and 2 for the grey. 1 of the grey tank vents is forward and connected to the kitchen sink drain pipe the other is for the tank. I donít understand why there would be 2? Does anyone know?
Tiangong is offline   Reply With Quote
Old 04-11-2018, 05:30 AM   #2
1994 30' Excella
Mississauga , Ontario
Forward one is to vent the sink drain pipe. If you didn't have it you might get a siphoning action which would suck the water out of the sink trap allowing sewer gas into the trailer.
Al
Al and Jean
TAC ON-3
Old 04-11-2018, 06:15 AM   #3
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
My 67 Overlander is set up the same way.
BambiTex is offline   Reply With Quote
Old 04-11-2018, 07:40 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Same same on my 75 Overlander. I wonder if there is some relation to the length of the drain run to the tank that would call for two (actually 3 gray water vents in my trailer). There are new "air emitter" devices that can be plumbed in downstream of the trap that open if they get any vacuum in the line. Some folks call the "vacuum breakers". These are easier than running another vent line.
Here is a photo of the drain plumbing in my Overlander behind the tub. The two pipes going to the bath wall tee together and up through the roof. One was bath sink and one was shower drain. The other vent line is forward in the galley wall and up through the roof.
No excuse for a gurgling drain in this Overlander.
David
Name:	1711 Bath Tub Out (Small).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Grey/Black Water Vents Broken? jnuechte Plumbing - Systems & Fixtures 1 01-22-2017 03:14 PM
Two vents for grey tank? Poolman Fresh Water Systems 7 02-09-2015 10:20 AM
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
Looking to replace black/grey tank vents polarlyse Waste Systems, Tanks & Totes 3 11-23-2014 08:48 PM
Sealing black and grey tank vents The Driver Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-03-2011 10:05 AM
