Old 11-15-2019, 07:37 AM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
winter water side preparations
I am lazy and want to be safe
i use the air blow out method and just anti-freeze in the traps.
I also bring in
  • my dual high flow main water filters
  • sink only triple drinking water filter
  • fresh water pump
I take the water filters apart and use CLR to get rid of any of the gunk, chlorine, lime, rust, calcium etx build up. It dries out all winter in the basement.
i throw away the filters each season, as they are relatively cheap to replace.
i run the pump through with CLR after removing and cleaning the 50 mesh inlet filter. I then run it through with distilled water and let it dry out
in the AS, i leave the low point drains open
I take out the plugs on the hot water heater and let it dry out. I always find there is a bit of water in the HW tank that i cant remove
all taps are left open inside
no problem in three years with this method
waninae39 is offline   Reply With Quote
Old 11-28-2019, 05:17 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is the new design so that i can easily remove the water filters and the water pump during the winter
Name:	new water setup-v3.jpg
Water side : getting ready for winter and upgrades waninae39 2005 and newer - Bambi all models 6 11-12-2019 07:26 AM
Shake down preparations shadesohippy Our Community 4 10-29-2019 08:29 AM
Upcoming preparations! sangeetaka Community Polls 4 04-26-2018 06:31 AM
Bad weather preparations.... kidsgone On The Road... 1 04-23-2010 03:39 PM
Sealing preparations for Land Yacht Roofs phred Land Yacht/Legacy Motorhomes 3 01-07-2005 07:32 AM
