Hello,
I’m in the process of de-winterizing my 2013 International 27FB.
I winterized by draining tanks, adding antifreeze to the fresh water tank and pumping RV antifreeze through the system.
Today I filled the fresh water tank in order to flush the system. I started by running the kitchen tap and then the bathroom. I wasn’t getting much pressure here and the flow was minimal.
I opened the valves to allow the hit water tank to fill and proceeded but no change.
The pump was working non stop and I went outside to confirm that the got water tank drain was closed and tightened.
This is when I saw water draining from a white tube beneath the trailer roughly below the hot water heater.
Does anyone know what this is and how to fix it? I’d never seen this tube before.
I’m attaching a couple of photos to illustrate.
Thank you
