Old 08-28-2018, 06:01 PM   #1
1978 31' Sovereign
Brooklyn , New York
What should I do with air in water pump lines and a leaky tank?
I just swapped out the old pump in my 77 Sovereign with a newer centrifugal pump, it immediately started making noise, it looks like somehow air was getting into the system. I filled up the tank a bit more, and noticed that water starts leaking into the cavity ( I had cut a small hole to access the water tank inlet ). I can't tell if it's the hose connection to the pump that is leaking or if the tank is cracked, but I'm wondering what my options are. I'm boon-docking on my property, and I have access to an external water tank, the only problem is there is not much pressure. Is there a way to use the internal pump, from the external source? Just trying to figure out what my options are.
estock is offline   Reply With Quote
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Noisy water lines when using fresh water tank Castaway Fresh Water Systems 14 12-17-2010 03:01 PM
Best position for water pump and lines bwaysteve Water Heaters, Filters & Pumps 1 01-19-2010 11:42 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
