Old 09-04-2018, 08:28 AM   #1
1977 31' Sovereign
Indianapolis , Indiana
What is this part?
The pipe/fitting below leaks when on city water or pump. It now drips water to the outside via plastic tube. What is it? Can I remove it? ...probably remove the other red-handled valve pictured below.
ID:	321484   Click image for larger version
jasonsherman is offline   Reply With Quote
Old 09-04-2018, 12:43 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like a pressure relief valve along with a pressure regulator. Probably original.
IMHO you should remove both.
Option 1: replace both.
Option 2: eliminate both and replace with exterior components which would be much easier to maintain and or replace.
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Replacement Sink / Shower Faucet part - No clue on part # natmoody71 Sinks, Showers & Toilets 0 03-07-2010 10:08 AM
Looking for pump part Craig Water Heaters, Filters & Pumps 2 01-09-2008 01:43 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
