RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-15-2021, 04:22 PM   #1
Baby Zeppelin's Avatar
2018 28' Flying Cloud
Clayton , Georgia
Water tank overflowing
Been on the road nearly a month now and have had our share of minor mishaps.
The latest is the fresh water tank overflowing when connected to city water.
I know it's the water pump check valve allowing water to back feed into the tank, but in the past running the pump for a second would clear the sediment, or whatever, holding the valve open and all would be well again. Well, so far not this time.
I don't want to have to replace the pump, or even take it out from under the stove and take it apart. Any ideas for unjamming the check valve, or is there an inline one I can install as a work-around?
Thanks!
Erik & Carol
Clayton, Georgia
AS: 2018 Flying Cloud 28 "Baby Zeppelin"
TV: 2017 Ford F250 Lariat w/ Blue Ox Sway Pro
AIRForums #126944 WBCCI #1297
Baby Zeppelin is offline   Reply With Quote
Old 01-15-2021, 04:39 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Run the pump for a longer time!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 01-15-2021, 06:16 PM   #3
1988 32' Excella
Robbinsville , New Jersey
You could try having the faucet open till no pressure in lines then cycle the pump a few times. Otherwise add a separate check valve or even a ball valve.
Old 01-16-2021, 05:40 AM   #4
Clayton , Georgia
How about one of these: https://www.amazon.com/gp/product/B0...1-dc3240e894a8 ?
Erik & Carol
Clayton, Georgia
Old 01-16-2021, 04:23 PM   #5
1988 32' Excella
Originally Posted by Baby Zeppelin View Post
Looks like it should work.
Old 01-16-2021, 05:06 PM   #6
Clayton , Georgia
I'll go ahead and place an order. Moved to a new campsite in another state park this afternoon and didn't bother to hook up our water hose to the spigot. May as well use up all that nice fresh water in the tank and not have to waste any by it overflowing....
Erik & Carol
Clayton, Georgia
Old 01-16-2021, 05:20 PM   #7
1986 31' Sovereign
Miami , Florida
I am a bit paranoid but when I don’t have full hookups with the gray valve open, I never use city water. If you use your fresh water tank and the pump, you will hear it come on if some fitting lets loose in the middle of the night or your beloved spouse doesn’t quite shut off the faucet in the bathroom. No chance of filling the gray tank to overflowing or flooding the trailer from a leaky junction...
Sure, you have to fill your tank every couple of days but a minor inconvenience.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 01-16-2021, 05:23 PM   #8
Long Island , New York
Quite a few times if necessary IMO.
Also, using an inline RV water filter in your potable water hose will help prevent grit in the pump's check valve in the future -- both when filling the tank, and when hooking up to city water.
And yes, using the tank is an excellent short-term solution.
Happy trails . . . and . . .
"Let the Music Lift You Up!"
Peter
Pressure relief valve overflowing on water heater... Argoz Water Heaters, Filters & Pumps 1 10-25-2020 10:27 PM
City water overflowing freshwater tank 223002104 Fresh Water Systems 17 05-08-2020 03:13 PM
Fresh water tank overflowing when city water connected hjnj Fresh Water Systems 11 09-16-2019 11:54 PM
Overflowing freshwater tank Kenogami 2018 - Current Globetrotter 2 07-20-2019 06:30 AM
City Water is Overflowing holding tank??? oldtrucksrul Fresh Water Systems 9 03-29-2014 12:38 PM
