11-15-2017, 12:54 PM
1985 29' Sovereign
Winter Park
Water tank leaks only when greater than 3/4 full
When I fill my tank, water starts running out of the metal support pan before it reaches full on the tank guage. I suspected a loose connection on the fill line as there is no leak when the level is below 3/4. I attempted to fill while observing the connections (on the street side of the tank) and no leaks were present on any of the connections. As I continued to fill, eventually water appeared, flowing from the street side along the bottom of the support pan.
When full to the point of leaking, and the water to the fill line shut off, eventually the leaking ceases, at I estimate 7/8 full. If you hook up and tow, I'll notice water leaking when I stop, untill approximately the guage reads 3/4 full.
I'm assuming I have a leak high on the tank, on the opposite side of the trailer from the fill. As long as I shut off the fill when the guage reaches 3/4, no leaks. As of right now, it's not worth it to me to go through the hassle of removing the tank, but I wouldn't mind having the full water capacity. Has anyone else ever run into this situation, and if so what was the source of the leak? The trailer is an 85 Soveriegn 29 footer.
11-15-2017, 01:32 PM
1994 34' Excella
Warren
, Manitoba
Are you also assuming that the gauge is reading correctly?? Most gauges that I have had in any of my rigs are not correct. I know when my tank is full, when it comes out the overflow, or if filling quickly through the tank fill, it blows back. I don't think you have a problem.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
11-15-2017, 02:21 PM
1973 21' Globetrotter
Houston
Well, that tank is 30+ years old...not hard to imagine that the tank has cracked, or that some previous owner drilled into it while installing flooring or fastening down a piece of furniture, etc..
The original water tank in my '73 held water fine when filled completely up, but the black tank had all kinds of cracks in it and had to be replaced.
good luck!
11-20-2017, 02:06 PM
1985 29' Sovereign
Winter Park
Thanks Belegedhel and CBWELL for responding. CBWELL, the tank never reaches the designed overflow before the water starts running from the opposite side of the tank. I think Belegedhel is on the mark. The previous owner made some floor repairs and I've backed out all the installed screws I can access and I don't think more than just the tip end of any of them could protrude through the decking. Either that is enough or like you say, a 30 year old tank could develop a crack. If thats the case I'm glad its apparently on top of the tank!
11-20-2017, 06:10 PM
Central
, Mississippi
Check the filler tubing for cracks. My 34' did the same thing and the problem was several splits in the tube. Much easier to fix than pulling the tank!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks, leaks, and more leaks
da_lizard |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
15 |
04-11-2016 12:36 PM |
Leaks, Leaks and more leaks
Jim in Pima |
5 |
12-12-2007 12:23 PM |
Leaks, leaks, leaks
jeffnjen30 |
8 |
08-28-2007 12:03 AM |
leaks leaks leaks
Globie64 |
10 |
12-31-2005 06:49 PM |
Argosy Values greater than Airstream?
Coastalview |
Trailer Values |
9 |
09-12-2005 11:12 PM |
