RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-01-2020, 01:07 PM   #1
2019 25' Flying Cloud
Pala , California
Water Regulator Issue...
Howdy!
I had a freeze last night and had to thaw hoses etc. Seems like I dodged a bullet!
BUT I have a Renator regulator which I put AFTER my 2 stage filter system right before entering the AS.
I try to keep it at 50psi.
When reassembling the outfit I notice that the pressure when faucets closed is 80psi and when open 45psi...
So is it reading 80psi just up to the regulator and then only letting 45psi enter the AS?
I believe the AS HAS a built in regulator so is this a non concern?
I think 80psi may be a bit high for the plumbing.... 2019 FC.
Trav
TravisH is offline   Reply With Quote
Old 12-01-2020, 02:17 PM   #2
2018 27' Globetrotter
Elbert , CO
I put the regulator upstream of the filter to protect both the filter and the trailer plumbing. Forgot to do this once with a cheap inline filter and pressure blew the casing apart - lesson learned!
djb75 is offline   Reply With Quote
Old 12-01-2020, 03:37 PM   #3
2021 25' Flying Cloud
Fredericktown , Ohio
I also place my regulator before the filter.
80 psig is way too high for the Airstream but both regulators should prevent that. No answer on the other question because I am not sure of your piping layout.
Good Luck.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
MMCMRET is offline   Reply With Quote
Old 12-01-2020, 04:58 PM   #4
1988 32' Excella
Robbinsville , New Jersey
I looked up Renator regulator online, the model I found had the gauge on the output side. If that matches yours freezing probably damaged it.
Old 12-01-2020, 06:37 PM   #5
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
I believe that all modern AS has regulator built inside...
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Possible regulator issue or leak? switters LP Gas, Piping, Tanks & Regulators 3 09-20-2020 10:53 PM
URGENT SAFETY ISSUE - Sturgis Regulator Recall khollister LP Gas, Piping, Tanks & Regulators 41 07-09-2016 06:59 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 11:19 PM
Odd Regulator Issue kamadeca LP Gas, Piping, Tanks & Regulators 4 06-16-2014 12:27 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 09:17 PM
