Old 06-25-2018, 10:28 AM   #1
1972 27' Overlander
Saline , Michigan
Water Pump replacement
my surflow 2088 water pump bit the dust.
I looked up replacement and saw surflow recommends 4008 model
I looked up the specs summarized below.
Old Surflow 2088 2.8 GPM, 3 AMP draw 40 PSI
New Surflow 4008 3.0 GPM 7.5 AMP draw 55 PSI
I have two concerns if we are boondocking the AMP draw on the new is over 2X the old also I don't know what my 1972 trailer original pressure relief valve is set to, IE is 55 PSI too high for my unit.
Has anyone else switched to a surflow 4008? that boondocks? is the higher AMP draw a problem?
loechli is offline   Reply With Quote
Old 06-26-2018, 05:06 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I have the 4008, though I didn't keep any of my original plumbing. Very unlikely you'd notice a difference between the power draw of the two water pumps while boondocking. Yes, it draws over 2x the power, but it's only ever on for a few seconds at a time. You'll run out of water way before you run out of power.
TheGreatleys is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
