Old 03-30-2020, 11:56 PM   #1
Los Angeles , CA
Water Pump 1973
Hello everyone! This is my first post. I'm a true rookie to all this stuff. Just purchased a 1973 31ft airstream. Learning as I go!
The airstream is not moving and never will. I'm living in it
As ai sit and chill out in silence, I hear a noise near the stove. Like a faint vacum. Could that be the water pump? How do you turn the water pump off to tell?
I'm not running any water and I'll be hooking up to my house this weekend. I don't need pump on if I'm running the city water. That's what I've been reading.
The only other thing it could be is the bater to the solar. Like I said, I'm new..
Thanks!
airhead123 is offline   Reply With Quote
Old 03-31-2020, 12:06 AM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Thanks!
Welcome to Airforums.
It sounds like it may be your stove vent fan running.
Be aware that most everything runs off 12 volts except for your air conditioner, the fridge and the appliance receptacles. 120 v also powers the converter that keeps your batteries charged that operate everything else. The noise also could be the converter (battery charger).
Dan
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
