Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 01-19-2017, 09:54 AM   #1
Roodman
Roodman's Avatar
1994 30' Excella
Redmond , Washington
Water pressure not sustaining on city water
Hey all- I've got a 1994 classic. Been in the same location for a year so I don't move it often. I'm at a campground. Water pressure has always been good. Had a big freeze and hose froze. Since then my water pressure is not good. When I turn on sink I have good pressure for about 15 seconds then it goes down to a trickle. I unhooked hose and the stream is still on the city side. Took off pressure valve and that didn't help. Anything else I can/should check? I don't see any leaking underneath. If I shut off sink and wait 30 seconds I have a strong flow but again only for 15 seconds
Roodman is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water pressure on city water Q CaCraig 1970 - 1973 Sovereign 10 08-27-2015 03:24 PM
water dripping from city water hose attachment location when NOT hooked up to city wa roscher Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
water coming out pressure regualtor drain line when on city water txstreamer Fresh Water Systems 7 09-16-2010 03:07 PM
no pressure when connected to city water tombhs General Repair Forum 8 06-28-2009 01:07 PM
