Old 04-01-2023, 11:36 AM   #1
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Water pressure fix
A while back, someone on the forum recommended removing my external pressure regulator that was conflicting with the built in regulator. Removing the external regulator did correct the low pressure issue, though I now have no protection for my outside filters and softener.
Any ideas?
- Stewart
s1000pre is offline   Reply With Quote
Old 04-01-2023, 11:49 AM   #2
2022 25' Globetrotter
North AL , Alabama
If your external regulator was adjustable, maybe put it back in place and try turning up the pressure a bit. I believe the internal regulator is supposed to be calibrated to 60 psi. Try running the external at 70 or so.
Tyler2you is offline   Reply With Quote
Old 04-01-2023, 12:33 PM   #3
s1000pre's Avatar
Fixed! I had it set to 70, though dropped to 30ish when the water was flowing. I cranked it up to 100 which is still 25 below the water softener max. It now flows at 60 psi and the water pressure in the trailer is good.
- Stewart
Water pressure regulator used to regulate air pressure? Atsushi Winterizing, Storage, Carports & Covers 8 10-26-2018 07:16 AM
Does on-board water pressure regulator protect against excessive air pressure? Hermes Winterizing, Storage, Carports & Covers 2 10-07-2018 02:25 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
To fix or not to fix nayl Ribs, Skins & Rivets 16 07-17-2010 08:38 PM
You Fix-You Camp-You Fix Some More juel Off Topic Forum 6 08-18-2005 07:50 AM
