Old 05-09-2024, 01:52 PM   #1
Charlotte , North Carolina
Water Miser Installation Question
I have a 28' Pottery Barn Edition, and I want to have a Water Miser diverter installed in the shower to conserve fresh water (and gray tank space) when boondocking while we wait for the water to heat up from the tankless system. Our showerhead is on the other side of our pantry wall, and the Airstream dealer wants $740 to do the plumbing and complete the Water Miser installation.
For anyone who has had this installed, does this make any sense? Of course I wouldn't do it at this price. What have others done, and how many labor hours did it take (or did you do it yourself?).
Thanks -
Patrick
Babyrocket is offline   Reply With Quote
Old 05-09-2024, 03:41 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I Googled "Water Miser", but I'm not sure what you want to install. Can you provide a link to what you are considering?
2019 Ford Expedition Platinum
Old 05-09-2024, 03:50 PM   #3
Here you go
https://youtu.be/YLI1FXNur80?si=MAkhpPFyE3GxzFXm
Old 05-09-2024, 05:53 PM   #4
dznf0g's Avatar
Oswego , Illinois
Installed mine myself in about 2 -3 hours. Different layout than yours, but I had to remove a closet floor and wall to get to the plumbing.
-Rich-
Old 05-09-2024, 08:24 PM   #5
Goes well with beer
1965 22' Safari
Statesville , NORTH CAROLINA
You can just buy an identical diverter valve and install it yourself. The changing color pipe is a bit gimmicky, all you have to do is run the hot water and count how long it takes for hot water to get there, or feel the valve itself. You can buy the valve here:
https://amzn.to/4ben2f8
Our camper is way older than yours, but the installation logic should be similar, so here is our write-up
https://shinyhappytravelers.com/plum...ess-hot-water/
Adventure Awaits, But Time Does Not!
www.shinyhappytravelers.com
Justen is offline   Reply With Quote
Old 05-10-2024, 07:48 AM   #6
Really helpful Justen (and Rich), much appreciated.
Old 05-10-2024, 09:40 AM   #7
2021 25' Flying Cloud
Edgewater , Maryland
Hi Patrick,
I have a 2021 25’ FC and I installed a shower miser on mine to help conserve water usage with the tankless hw heater. We now use it to heat up water for the bathroom and kitchen sinks. We both view it as a must have upgrade with the tankless system.
I installed it myself in less than 2 hours. Total cost was less than $200 including PEX tools that I did not have yet, but wanted to have on hand anyway.
I agree with the earlier post that the mushroom color changing part is not necessary and saves a hole cut in the shower; we just count to 15 and the water is hot for a shower. The hole cut in the shower stall is the most nervy thing too so I did not want to do 2. There is a separate shower miser version without the color changing mushroom.
I used and edited instructions from a prior post and can share if you want to do it yourself. Granted your configuration will be a bit different, but the concept is the same.
I can see with parts at $200/hr labor that a dealer could get up towards $700ish, but it would be 3 hrs of labor which seems a bit high.
Message me if you want to see my edited installation instructions and pictures.
Cheers, Greg
Dr. Ohat is offline   Reply With Quote
Old 05-10-2024, 10:33 AM   #8
27ftToaster's Avatar
2021 27' Flying Cloud
Wake Forest , North Carolina
I installed this diverter valve in my 2021 27’ FC and diverted the water back to the fresh water fill hose. Fairly easy if you are handy. No holes drilled in shower. This fits between the shower wall and the closet. It has significantly reduced the amount of water we use in the shower. It allows you to take more time soaping down and washing hair, as previously with our tankless heater we were doing “speed showers”. You will be very happy with whichever solution you choose for recirculating the water!
https://a.co/d/0sETdZG
2021 27' Flying Cloud FBQ, Rear Hatch,
480w Solar, 400ah Lion Energy Lithium,
3000w Multiplus II, Dual Orion 30a DC-DC Chargers (60a total), 3" Lift kit, Maxxair Fan
2020 RAM 2500 6.7L Cummins Diesel
27ftToaster is offline   Reply With Quote
Old 05-10-2024, 11:10 AM   #9
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
(Edit: @27FT beat me to the punch)
This is on my upgrade list as well. I am leaning towards this solution which uses a valve with a diverter to a tub (in our case the freshwater intake) - no holes required. It's more expensive ($130) but the new mechanism is classier and probably better than the original valve.
Links:
Handle
Valve
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 05-10-2024, 11:24 AM   #10
JeffKim's Avatar
2021 16' Bambi
This looks like both the handle and valve. When I was researching this it appeared it was discontinued and the handle and valve are now separate products which after shopping around are much cheaper. I'll have to confirm the combination I posted is correct.
2017 Audi Q7 3.0T
WBCCI 6343
Old 05-10-2024, 05:32 PM   #11
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
Leave well enough alone
Life is a Highway is offline   Reply With Quote
Old 05-10-2024, 06:44 PM   #12
2022 27' Globetrotter
Bethlehem , Pennsylvania
See post 49 and 51 for DIY instructions. Works great. Highly recommend.
https://www.airforums.com/forums/f44...ml#post2639946
Took me about four hours to install it. Biggest issue was taking the closet apart on the 27FB. I took my time. Your fresh tank is on the same side as the shower, so it should be fairly easy.
Merlintiaga is offline   Reply With Quote
Old 05-11-2024, 10:14 AM   #13
JeffKim's Avatar
2021 16' Bambi
Can you clarify this? It's not worth the effort?
2017 Audi Q7 3.0T
WBCCI 6343
Old 05-15-2024, 09:08 AM   #14
2023 27' International
Oceanside , CA
I installed a "Miser" in our '23 27International along with a pump controller. It works flawlessly! I didn't add the "purple" indicator as you don't need it. I did notice that the hot water (on demand) works better with the pump controller. I'll probably add a solenoid valve to the galley controlled by a 40second timer for instant hot water (without waste or gray tank filling). IMO these should be standard on trailers with on demand hot water systems.
O-side Jimmy is offline   Reply With Quote
Old 05-15-2024, 05:24 PM   #15
CB2
2004 30' Classic
Billerica , Massachusetts
So it seems like a pain, but we currently have a low flow shower head and we hold a pitcher under the shower until it heats up, then we either dump the water back in the fersh tank or use it for other purposes. It is an inexpensive fix to the problem and $0 cost
CB2 is offline   Reply With Quote
Shower miser in 23 fbt Escape21 Sinks, Showers & Toilets 66 03-26-2024 05:34 AM
Shower Miser on a Basecamp 20X madmac157 Plumbing - Systems & Fixtures 0 02-16-2024 07:23 PM
Shower miser Dennawayne Plumbing - Systems & Fixtures 1 01-13-2024 10:42 AM
Shower Miser in 2033-25 RBT Intl JimChase Plumbing - Systems & Fixtures 2 07-03-2023 12:48 PM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
