Old 04-23-2008, 05:44 PM   #1
1966 22' Safari
Angier , North Carolina
water inlet cover won't budge
I have a '66 Safari, and I can't get the inlet valve cover to budge. It looks like it might have had a handle on it at one time, but there's nothing there now. It is either wedged/gummed shut, or there's another way to get it open that I just don't know about. Help? I know I have to replace the fresh water tank, but that's another story. Is there a different hose hook-up for city versus tank fill? (I guess you can tell I'm new at this)
AngierAnne is offline   Reply With Quote
Old 04-23-2008, 11:47 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
First, welcome to the forums!
Not sure about your year, most trailers have a city water hookup at, or near the rear bumper on the left side.
My '72 Globetrotter had a locking door that just swings down to gain access for filling the tank. (I sold it)
Hopefully tomorrow you'll get some input when they all wake up...
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Old 04-24-2008, 06:33 AM   #3
. , At Large
I think the '66 had a tank mounted in the front of the trailer, on the floor, side to side.
Is there a way to get at the inside of the door? Maybe from inside the trailer? A does of WD40 or similar on the hinge, and a judicious push from within may get things moving.
Old 04-24-2008, 06:40 AM   #4
centennialman's Avatar
2016 23' International
Centennial , Colorado
Hi Angier......I also have a 66 Safari and love her!!
The city water hook up is inside the rear access door. I re-plumbed mine so that it hooks up on the back side of the trailer and I don't have to feed the hose into the rear compartment. Before that, I fed the hose up through a pipe that comes out the left rear bottom of the trailer (where the power cord drops out). Look there and let me know if you don't locate it.
Your water tank is under the dining table and runs side to side at the front of the coach. There, generally, is a wooden cover built over it and the pump should be on the left side under the seat towards the front of the trailer.
I am not sure how to tell you to open the cap from the outside. Mine opened without any problems. Be careful with it though...you don't want to damage it. If I remember correctly, Inland RV may have replacement caps if you do end up damaging it.
I have done quite a few things to my Safari and can answer questions for you, so, keep in touch and good luck.
Got an pics of yours? We all love to see inside and outside pics!!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-24-2008, 06:44 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
water inlet
A photo would help.
If this is the plastic Thetford type for filling the fresh water tank and it has not been used for a while it could be stuck. I would try gentle side to side prying/ wiggling to pop it loose. If it is the one I am thinking of, new are available and cheap.
Where oh where is the water inlet????? Hamb7 Fresh Water Systems 13 01-10-2011 07:15 PM
City water inlet Davis Fresh Water Systems 2 02-13-2008 07:41 PM
60s Water Inlet Safari Tim Fresh Water Systems 7 10-25-2006 12:49 AM
Fresh water inlet William Ales Fresh Water Systems 0 10-11-2006 08:32 PM
City Water inlet AYRSTRM2 Fresh Water Systems 5 06-08-2004 06:57 PM
