Old 03-18-2025, 04:54 PM   #1
2019 23' Flying Cloud
Hillsborough , North Carolina
Water Flow
I recently purchased a 2019 Flying Cloud 23FB. The water flow in both the kitchen and bathroom faucets is about .5 gpm. The shower is about .75 gpm (with the wand removed). It is very similar with city water (about 30 psi) and with the water pump. This is my first RV but this seems really low. The RV was used very little by the previous owner. Is it low? If yes, how would I troubleshoot this?
Barry Weston is offline   Reply With Quote
Old 03-18-2025, 08:30 PM   #2
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
First do the easy thing. Remove and clean the screens on the kitchen and bath taps.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 03-19-2025, 07:32 AM   #3
2022 33' Classic
Chesapeake , Virginia
OP could also remove the sediment trap off the water pump, there may be debris in it.
BGClassic is offline   Reply With Quote
Old 03-19-2025, 06:03 PM   #4
Water Flow
Thanks of the suggestions.....Does anybody know what the "aerator" in the kitchen sink is in the 2019 Flying Cloud? It is not the usual aerator like most faucets and it looks to require some type of special tool to remove it. I can try to take a picture tomorrow and post it if people need a photo to see my "problem" with removing it. I will take the one off the bathroom sink tomorrow and clean it and I will remove and clean the "strainer/filter" on the water pump tomorrow but, unless city water also flows through this "strainer/filter", I am not optimistic that this is the underlying issue.
Old 03-20-2025, 05:41 PM   #5
Water Flow
I did get both of the faucet aerator/strainers off. Sand in both. Flow is now about 1.5 gpm with the pump running and about 1.25 w/o the pump. Some better without the aerator/strainers but they are a necessary device. My city pressure is about 35 psi. My understanding is that the pressure with the pump running is about 60 psi. I am satisfied with 1.5 gpm. Thanks.
I am buying an inline filter and PRV for the city connection.
Old 03-26-2025, 09:12 AM   #6
2016 23' Flying Cloud
ROCK HILL , South Carolina
Barry We have the same model 2016 FC. Water flow has always been the same and never high pressure. I replaced the water pump, ug what a miserable job, and cleaned the screen. That helped but not much. Same pressure no matter what campgrounds we’re at.
20TIRES is offline   Reply With Quote
Old 03-26-2025, 09:48 AM   #7
2015 23' FB International
Vail , Arizona
Might try installing a Shurflo Accumulator Tank downstream of your water pump. It will even out the variable pressure surges caused by the pump. Installed mine under the bathroom sink of my 23' FB. Aerators will need frequent clean out too. Lots of junk accumulates in RV freshwater systems.
recharge37 is offline   Reply With Quote
Old 03-31-2025, 08:13 AM   #8
2019 30' International
Spring , Texas
Our 2019 International 30' has a quick connect filter under the sink from the water line to the faucet assembly. This is also a flow restrictor, and it was the lowest gpm available. I replaced it with a higher gpm filter. That helps some.
With low flow at all faucets, your mixing valve on the water heater is likely plugged up with sediment. This will happen unless you flush your hot water tank very well after winterizing. It may happen anyway. Plenty of discussion on this site regarding the mixing valve issue. On my model I have to remove the dinette bench to access and clean the valve.
StanA is offline   Reply With Quote
Low H.Water flow & City Water Inlet / Backflow Too tall Water Heaters, Filters & Pumps 6 03-09-2022 06:31 PM
Water heater and water flow? GypsyKarma Water Heaters, Filters & Pumps 17 12-06-2016 03:42 AM
No water flow after hooking to city water Grevers911 Fresh Water Systems 8 06-23-2013 10:08 PM
Water flow question... Sneakinup Waste Systems, Tanks & Totes 1 05-19-2004 06:20 PM
No water flow Michael W Plumbing - Systems & Fixtures 4 10-12-2003 08:26 PM
