Old 05-11-2024, 08:19 AM   #1
2022 25' International
Dallas , Texas
Water Drip Outside at City Inlet
Woke up this morning to a large pool of water around our camper. There is a periodic drip at the city inlet connection. Iíve tried tightening but that doesnít seem to do anything. Does anyone have any recommendations?
Texarado is offline   Reply With Quote
Old 05-11-2024, 08:41 AM   #2
Mollysdad's Avatar
Can you tell where the drip is coming from? Inside or outside?
If it's inside, by removing the four screws, you "should" be able to pull the built in regulator out enough to see the connections.
If it's outside, I recommend using a new washer and then attaching a "quick connect" of some type that doesn't need screwing and unscrewing.
My hose has become a science project with quick connects everywhere, but I've had the same inlet connector on my last MH and the Airstream for 20 years without a drop.
Old 05-12-2024, 05:48 PM   #3
SandKSmith's Avatar
Phoenix , Arizona
We had a similar problem. It turned out to be a hairline crack in the back side of the fresh water hose connection. There is a built in pressure regulator and check valve integrated into the fresh water hose connection too. Ours must have frozen at some point. There is probably a panel somewhere to gain access to it on the inside. Ours was in the back of a closet.
Good luck
Steve
SandKSmith is offline   Reply With Quote
Old 05-14-2024, 08:38 PM   #4
2017 25' International
West Lake Hills , Texas
Is the water heater on or off? Back pressure from heated water may cause the inlet to leak. Solution is to tighten it from the backside of the inlet. I added thread tape. Seems to work.
Fungus is offline   Reply With Quote
Old 05-14-2024, 09:14 PM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Replacing the fresh water inlet connection might be the solution. Can you find a way to peak behind it?
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 05-15-2024, 08:00 AM   #6
aftermath's Avatar
Spokane , Washington
I have the same trailer as Steve and have replaced mine twice. Actually just once but the replacement was faulty so ......
On my '06 25FB there is an access panel at the back of the closet. Once removed, it was a straight forward process. I really like the original design with the turn star for tightening up the hose. Had to replace a few washers over the years but that has been it. Owned our trailer since 2009.
aftermath is offline   Reply With Quote
Help, drip drip leak behind wall at city water inlet Arnoldjeff Fresh Water Systems 19 11-21-2021 05:51 PM
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 07:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
