Water Access Cover
Good Day,
I have a 2016 19' Flying Cloud. I'm upgrading the various exterior plastic covers and elements such as the range hood vent cover, Cable/Satellite connectors and the portable water access compartment.
The first two components were an easy switch out, but when we got to the portable water access cover/unit, I discovered there is literally no excess tubing (of the fill tub and air pressure tube) to pull out in order to change out the access unit to a stainless unit. Then, I thought attack it from inside via the access panel on the dinette seat, but where the tube connects to the water tank are well under the fixed seat panel.
Anyone every change the water fill access panel out? Any feedback is appreciated.
