Old 01-19-2019, 12:00 PM   #1
2005 28' Classic
Palmdale , California
Tank full
I'm sort of new to the forum so forgive me if this question has been answered before. I have been in this resort for about two months and just noticed that my fresh water tank is over flowing. This tank was empty when we first arrived. Can my city water valve be leaking. Thanks ahead for any thoughts.
mikeadams is offline   Reply With Quote
Old 01-19-2019, 02:15 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Most likely it's the check valve on your water pump.
TheGreatleys is offline   Reply With Quote
Old 01-19-2019, 02:36 PM   #3
Trailer Sold, Waving
Acheron2010's Avatar
2019 26' Flying Cloud
Stettler , Alberta
Happened to me too. Yes, water pump check valve. Use it a few times and it starts "checking."
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 01-19-2019, 03:07 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Agreed. Fresh water pump check value failure - when it fails allows city water under pressure to back flow into the fresh water tank.
wulfraat is offline   Reply With Quote
Old 01-19-2019, 03:47 PM   #5
RVATOR
Toornburg's Avatar
2018 28' International
2023 33' Classic
Dallas , Texas
Not sure who advised us on the same issue. They said it can often result from high water pressure from site overwhelming check valve. Suggested disconnecting from water supply, running only from internal supply on pump until almost depleted. Then, resume hookup from site. Worked for us and did not require replacing check valve.
___________________________________
RVATOR
2018 AS International 28’ RB-Twin
2023 AS Classic 33’ FBQ
RV-7 (N23KT) VANSAIRFORCE.NET
Toornburg is offline   Reply With Quote
Old 01-25-2019, 06:39 PM   #6
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
This did the trick for me when it happened
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Old 01-26-2019, 04:55 AM   #7
Sag Harbor , New York
Ditto on the pump's check valve.
See these search results:
https://www.google.com/search?q=pump...=airforums.com
Recent threads:
http://www.airforums.com/forums/f443...nk-190805.html
http://www.airforums.com/forums/f163...ff-190997.html
Check the list of topics in this sub-forum for other threads: http://www.airforums.com/forums/f443/
If you are not careful to always use a filter on the hose [both for city water and filling the tank] grit from the water supply can compromise the operation of the valve.
Try turning the pump on and off lots of times, and pressurize the system with city water on and off a bunch of times. Often the problem will go away. If you have time, drain the fresh water tank and monitor the last gallon or two for grit. Use a filter like this one when you fill the tank:
https://www.amazon.com/Camco-TastePU...r+filter&psc=1
Good luck,
Peter
Full Time Streamer versus other full time RVs rodsterinfl Full-Timing 31 01-18-2016 05:31 PM
FULL time Trailer or FULL time Motel? Ray Eklund Full-Timing, Winter Living & Workamping 40 07-06-2015 06:11 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Parked with full hookups and full water tank question badkat Plumbing - Systems & Fixtures 16 10-18-2013 09:32 PM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 09:31 AM
