Old 02-08-2024, 12:24 PM   #21
dznf0g's Avatar
Oswego , Illinois
Well, I'm looking at my regulator right now at white tank regional park. My regulator is set at 60 psi, and the gauge reads 60 psi.....so park pressure is 60 or more.
-Rich-
Old 02-11-2024, 10:46 PM   #22
1999 28' Excella
Lake Mary , Florida
Why depend upon a cheap pressure reducing valve to protect you from a burst water line? Just fill you tank and use the internal 12V water pump, that is why you have a pump. I have a 20 year old 12v pump on my boat, same model as used in my RV, and it still works fine. That way I never worry about a runaway pump in the RV park distribution system blowing out all the fittings inside my RV
suncoasteng is offline   Reply With Quote
Old 02-12-2024, 10:38 AM   #23
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
We do the same thing - use the fresh water tank exclusively. We recommend that anyone connected to "city water" be sure to turn off the water supply when you're away from your RV.
Back to the O.P. - we replaced our city water inlet recently and also realized the old 50 psi and new 65 psi numbers. 65 is all that's currently available unless you come across new-old-stock. So, we went with 65. As I mentioned, we don't use it but want the trailer to be fully functional so it's there if needed.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-13-2024, 04:31 PM   #24
2021 16' Caravel
2022 23' Globetrotter
Callao , Virginia
Recommend a regulator?
Can anyone recommend a specific external regulator to use? Perhaps with a link to Amazon?
Karl
kmrice is offline   Reply With Quote
Old 02-13-2024, 04:51 PM   #25
1988 32' Excella
Robbinsville , New Jersey
Karl
I like this type.
https://www.amazon.com/Hourleey-Pres...zcF9tdGY&psc=1
Old 02-14-2024, 09:06 AM   #26
2021 16' Caravel
Callao , Virginia
Thanks!
Thanks! Looks like just what I need.
Question about the SHURflo City Water inlet and Pressure regulator Peter C Fresh Water Systems 0 08-30-2021 04:31 PM
City water inlet and potable water inlet replacement sizing? LiamO86 Sprinter and B-van Forum 2 05-09-2019 06:05 PM
100 PSI or 70 PSI? '92 300LE fangthorpe Airstream Motorhome Forums 5 09-16-2010 11:11 AM
shurflo city water inlet urbanfood Fresh Water Systems 3 08-19-2007 04:25 PM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 10:54 AM
