Old 04-10-2020, 02:14 PM   #1
Lake Charles , SW Louisiana
Seeking Advice - Water Compartment Inlets
I have a very new-to-me 2018 Classic M30 RQB and a question about the water inlets located inside of the exterior water compartment.
Can someone educate me on the difference between the 2-two separate water inlets located inside my exterior water compartment?
I understand from reading the Owner's Manual that the one shown on the left in the attached photo and marked City Water Inlet (potable water only) is the one I would most commonly use when connecting up water supply and is supported by a built in 55 psi regulator BUT I have no idea what the one marked "Water Inlet" on the right is, further-to-which is not addressed in the owner's manual. Both have female garden hose connection threads and screw in cover caps.
Name:	WATER INLETS.jpg
"Finding the Roads that Await Us!"
Rick & Lydia Williams
'18 Classic M30 RFB w/AMSolar' 600w Victron Energy/V4 Lithium Power, ProPride 3P, etc.
rewillia is offline   Reply With Quote
Old 04-10-2020, 02:22 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
one is for drinking water- use the white hose.
the other SHOULD NEVER the white hose- use a green one.
The smaller valve is for flushing the black tank. Read the owners manual, it is clearly marked there. If you use the white hose on the smaller inlet, you may get back flush from the black tanks. This could make everyone sick in the AS
waninae39 is offline   Reply With Quote
Old 04-10-2020, 03:18 PM   #3
Ahh, the beauty of the Air Forums.
Waninae, Thank you for the clarification. I have since (at your advice) gone back re-read the OM and as you stated, I now know the difference only just a bit surprised AS does not label the inlet as the black tank flush water inlet instead of just "water inlet".
Again, thanks.
Decision on 30A versus 50 amp inlets jeremyHB Electrical - Systems, Generators, Batteries & Solar 16 12-16-2019 12:53 PM
Rubber grommet inlets for black tank? vhord Waste Systems, Tanks & Totes 3 03-20-2008 01:02 PM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-22-2007 11:03 PM
Desperately Seeking Hipster Fulltimers/Advice! iamsusanq 2002 - 2005 International 17 12-08-2004 08:50 PM
Seeking Advice.... jtshipp On The Road... 9 05-17-2004 04:42 PM
