Old 11-23-2019, 07:53 AM   #1
2011 23' Flying Cloud
Durango , Colorado
Replacement Tank Level System
All three (fresh, grey, black) tank level indicators on my 2011 FC 23FB have failed. Tried the system reset, nada. My dealer estimated >$800 to replace the entire system, mostly labor as it involves dropping the tanks. As these level indicators were never very accurate nor reliable, Im holding off pending more research.
It disappoints me that Airstream does not design better accessibility to parts that can be expected to require replacement.
Id appreciate input from anyone who has installed a better system.
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-30-2019, 11:51 AM   #2
2014 25' FB International
Santa Cruz , peterputt
Had the same problem with our 2014. The existing system was the Micro Pulse and it never did work for us. (Bought AS used about a year ago). I've been in the process of changing over to the SeeLevel II system. I can attest that removing the pans is a challenging task if you've never done it before. Solo is worse! Having said all that, I've now got the black/grey tank pan back into place. Discovered a cracked fitting for the fresh water suction outlet and had to figure out how to repair rather than buy a new tank. (Google spin welding). Last step is to reinstall the fresh water tank and pan and test. $800 for someone else to do it seems reasonable unless that cost grows which it probably would. Anyway, my two cents :-)
peterp is offline   Reply With Quote
Old 11-30-2019, 11:54 AM   #3
Water tank comes down with the pan on our 25 Intl. Black and grey will stay in place (at least for our unit)Click image for larger version
ID:	357071Click image for larger version
Old 11-30-2019, 11:56 AM   #4
Cracked fitting on left, repair in second picClick image for larger version
ID:	357073Click image for larger version
Old 12-01-2019, 08:18 AM   #5
Durango , Colorado
Originally Posted by peterp View Post
Cracked fitting on left, repair in second picAttachment 357073Attachment 357075
Thanks for the detail, Peter. I think Ill defer replacement of my sensors until I can do it myself. Id like to create access to the sensors with cutouts in the trays, improve the insulation, add heat tape for freeze protection.
Safe Travels,
Joe & Joan Donnaway
Durango, CO
No kidding. How level is level? upnorththree Towing, Tow Vehicles & Hitches 19 03-25-2017 01:14 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
Tank level monitor suggestions for new black/gray tank redreefet Waste Systems, Tanks & Totes 5 06-28-2012 06:39 PM
See-Level system installed crispyboy Waste Systems, Tanks & Totes 9 07-05-2011 05:45 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
