Old 03-01-2021, 09:54 AM   #1
Kansas City , Missouri
Plumbing replacement.
Hello everyone.
Relatively new to this, and I have been experiencing leaks in plumbing off/on in my 1965 Caravel.
We have replaced some areas, then another leak pops up. What we used to replace joint/fittings was Aqualock. I will include a pic of type of plumbing.
Essentially I am told and would be more comfortable than (what seems to be every 3 day a leak popping up) that I need to replace plumbing with PEX.
I am in Rockport Texas, and know there is an older Airstream restorer 2 hours away, but very busy. Another clinic may be able to help, but I'd prefer someone who knows older airstreams.
Any advise around this area or in general?
I'd like to get the job done sooner than later if at all possible, since I have no water source at the moment.
If I took it to a camper clinic I am wondering if that would suffice, even if they do not work on older Airstreams..?
Thank you!
rambler1970 is offline   Reply With Quote
Old 03-01-2021, 11:10 AM   #2
1970 23' Safari
Marion , New York
There is nothing special about Airstream plumbing from other types of trailers, except for maybe being over engineered. I would think that any RV service area could do the job for you. You might even want to get quotes from a regular household plumber, if you can find one willing to work on a trailer.
DremStremer is offline   Reply With Quote
Old 03-02-2021, 01:28 PM   #3
1963 19' Globetrotter
Orion , Illinois
Replace it all yourself
Instead of chasing leaks just replace it all . PEX makes it a pretty easy job . Hardest part is getting into some of the spaces. Lots of You Tube on working with PEX. There are a number of ways of connecting it but I favor all 1/2" and Shark Bite or similar fittings. Home Depot or similar stores will have everything you need. Biggest thing on working with PEX is you need square cuts , so do yourself a favor and spring for a quality cutter for the PEX. To get the old stuff out , a close quarters tubing cutter is your best friend.
63air is offline   Reply With Quote
Old 03-02-2021, 07:05 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
PEX is the way to go. I use chinch clamps instead of the "sharkbite" push to connect fittings, but either will work. Big box stores have all the materials you will need.
It is a job to gain access to the plumbing as it runs behind and under the cabinetry. The PEX plumbing I have done was when I had removed most of the cabinets. They needed rebuilt anyway.
David
Name:	2101 Plumbing Faucet Valves.jpg
ID:	389761   Click image for larger version
Name:	2101 Plumbing Pump.jpg
WBCCI #8607
VAC Region 11
See my 1969 Globetrotter 21' Renovation Project:
In Knowledge Base
See my 1966 Trade Wind 24' Reno Project:
In Knowledge Base
See my 1975 Overlander 27' Improvement Journal:
In Knowledge Base
See our 1976 Sovereign 31' Renovation Project:
In Knowledge Base
Old 03-02-2021, 07:16 PM   #5
1966 22' Safari
Fredericksburg , Texas
Thereís supposedly a couple of places around Houston which is not that far. Unfortunately, the most popular vintage Airstream shop is just SW of Ft. Worth. A&P Vintage Trailer Works in Paradise (Ann and Paul). But like Conifer David and 63air said, PEX is paramount. You really donít need to be an airstream expert to repair/replace with PEX. Good luck
Bubba L is offline   Reply With Quote
Complete Plumbing Replacement Knox Al Plumbing - Systems & Fixtures 3 03-30-2017 12:42 PM
plumbing replacement Tesla77 Plumbing - Systems & Fixtures 2 10-15-2015 07:23 PM
Plumbing replacement work in Springfield, MO? Blimphauler Plumbing - Systems & Fixtures 1 02-02-2007 09:28 PM
Plumbing system replacement sckerber Fresh Water Systems 7 06-05-2006 09:56 AM
plumbing replacement Tin Tortuga Plumbing - Systems & Fixtures 17 08-20-2005 10:00 PM
