Old 09-22-2019, 03:15 PM   #1
43687269734F's Avatar
1962 16' Bambi
Ann Arbor , Michigan
Plastic fresh water tank - Filler boss
OK, the more I learn about plumbing the less I know.
So I've got these exciting new water tanks that come with the "industry standard filler boss". So... the big question is... what connects to this filler boss? All I have is about 2 in of non-thread plastic pipe, 1 1/4" O.D.
Did not find anything specific to my question, on AF or from general searching, except for this part:
https://www.rvpartscountry.com/Fill-...Straigh-thtml.
Which might look relevant kinda sorta
The only Boss I know of is Bruce, and this ain't no Bruce.
-Chris O
43687269734F is offline   Reply With Quote
Old 09-22-2019, 04:57 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
https://en.wikipedia.org/wiki/Boss_(engineering)
^^from this website^^
"In engineering, a boss is a protruding feature on a work piece. A common use for a boss is to locate one object within a pocket or hole of another object. For instance, some motors use a precisely machined boss on the front face to locate it on the mating part. Like a process on a bone, bosses on castings can provide attachment points or bearing surfaces."
I learned this in high school, mechanical drafting class.
Screw a male threaded plumbing adapter into the boss' threads. Connect a tee to the existing cold water pipe. Place pipe with a valve between the new tee and the adapter. With this you can fill the tank when the trailer is connected to a water supply.
At one time this was an option on Airstream trailers.
Or,
If the threaded opening is large enough that it will receive the pipe for the external filler spout, you can go that direction.
Or,
You can use this threaded opening to create an air vent.
Alan
Old 09-22-2019, 05:02 PM   #3
1962 16' Bambi
Duh, this answers my question:
https://www.vintagetrailersupply.com...m?1=1&CartID=0
Use fill hose with clamp going to the boss on the fresh water tank.
Not as complicated as I originally hoped.
-Chris O
Old 09-22-2019, 05:19 PM   #4
1962 16' Bambi
Thank you Alan, really good ideas.
Unfortunately the boss is not threaded, and has an unusual O.D. of exactly 1 1/4", which doesn't map to any piping standard I've encountered yet. Of course all of plumbing confuses the heck out of me ; -)
But I just might have found something simple:
Clamp this hose on the boss and you're good to go. Found that by looking for a replacement cap for the filler neck, should've checked VTS first.
-Chris O
Old 09-23-2019, 07:26 AM   #5
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
Denver , Colorado
You can also purchase a rubber boot with hose clamps at any big box store that will allow you to go from the boss to whatever size pipe or hose you prefer.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 09-23-2019, 11:18 AM   #6
1962 16' Bambi
Thank you kidjedi, that makes sense.
-Chris O
Old 09-23-2019, 01:23 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
That should work just fine. I replaced the filler hose on my 34' a couple months ago, but mine was threaded. The threaded adapter was 1.25" OD to receive the filler tube.
Alan
Old 09-23-2019, 01:33 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You will need 4 openings for pipes.
Near the top - water inlet from the filler.
Near the top - outlet for air vent/overflow to exterior
Near the bottom - water outlet connect to pump
Near the bottom - drain to exterior for winterizing
Is there a bung plug in your tank?
If the tank is above floor, that bung goes upward.
If the tank is below floor the bung goes down.
The bung needs to be accessible without removing the tank and plumbing.
Alan
Old 09-24-2019, 02:21 PM   #9
1962 16' Bambi
Yes! Four pipe connections , two on top and two on bottom, for maximum connectivity. Will check on the bung plug, thanks for the advice.
-Chris O
Think Your 4-Wheel Drive is Boss? pappy19 Tow Vehicles 1 02-14-2016 06:09 PM
Undercover Boss: KOA CEO - CBS, Friday, 01/11/13, 7pm CT & MT, 8pm ET & PT Phoenix Off Topic Forum 3 01-14-2013 10:20 AM
Fresh Water Tank Filler Dano57 Fresh Water Systems 23 12-17-2006 06:55 AM
Friday is Boss chikagurl Off Topic Forum 3 08-31-2005 05:46 AM
Fresh water filler tube '63 Safari srgntpepper Fresh Water Systems 5 05-27-2004 07:16 AM
