Old 06-24-2018, 09:01 AM   #1
2015 27' Flying Cloud
maple grove , Minnesota
Question No water in kitchen faucet
2015 Flying Cloud 27FB-just dewinterized(I used antifreeze to winterize) and found no water comes out of kitchen faucet or spray. All other faucets work great.Valves under sink are open. Talked to Moen and they suggested replacing the cartridge which I just did. Still no water. Any ideas?
thebreezeman is offline   Reply With Quote
Old 06-24-2018, 09:06 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Most likely crud in the faucet. Should be a strainer in the faucet and in the spray unit that you can access by unscrewing the nozzles. I have to do that every year. Sometimes I have to replace the shower head because the ones I use do not come apart.
Old 06-24-2018, 09:42 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If no water from either faucet or sprayer, there is a 'supply' problem.. try loosening the cold water side fitting and turn on water pump. Watch for leak.. If water is moving, then the problem is in the valve.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-24-2018, 10:04 AM   #4
No water in kitchen faucet-Fixed
Thank You. It was the screw on screen!
Old 06-24-2018, 10:11 AM   #5
Caffeinated's Avatar
Portland , Oregon
Two stage external water filters will help greatly with that. First stage is a sediment filter. Second stage is charcoal with stuff for lead, cysts, bacteria, etc. rv water filter store dot com is where I got mine, after my shower handle got so messed up it wouldn't turn.
Mike
Caffeinated is offline   Reply With Quote
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 10:20 PM
single hole faucet for kitchen sink IPM Airstream Motorhome Forums 8 08-10-2004 07:17 AM
Installed new kitchen faucet! Stefrobrts Fresh Water Systems 18 07-16-2004 11:33 PM
kitchen faucet leaking Stefrobrts Fresh Water Systems 10 03-16-2004 09:44 AM
Kitchen Faucet Repair niftypkg Sinks, Showers & Toilets 13 09-27-2002 05:02 PM
