Old 09-26-2006, 12:02 PM   #1
Hello,
I have been reading the winterizing tips. We are new to Airstreams and purchased a 1967 Safari earlier this year. We filled the fresh water intake tank full during the summer and found after opening the drain, and seeing only drops trickle out, that someone may have put leaves (something green...or calcification?) that have clogged the drain (there is no lockable cap on the intake tank). Little leaves can be occasionally pried out by using a wire as a snake. Compressed air forced up the drain hose has also not worked. Has anyone encountered this problem?
Any help appreciated,
jvandal is offline   Reply With Quote
Old 11-06-2006, 01:23 PM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. We once had a gravel substance in the tank from a campground well but never leaves. I wonder if you keep filling the tank if you could wash the leaves out the top or try draining and filling at the same time to rinse out the tank.
Hopefully someone else will chime in here.
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Old 11-06-2006, 01:45 PM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Looks like a pretty old thread, wonder if he found a solution
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
2007 GMC Sierra 2500 HD Duramax
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-06-2006, 01:53 PM   #4
1976 25' Caravanner
Campton , New Hampshire
If you can rig up a garden hose connection at the drain valve you can try back flushing letting it come out the fill spout . You may also try double chlorinating and letting it sit for a few days , this will sometimes desolves small things , not recommended if you have a galvinized tank , only plastic or stainless steel . Good luck
ticki2 is offline   Reply With Quote
Old 11-06-2006, 03:10 PM   #5
1972 25' Tradewind
McHenry County , Illinois
Question Drain Valve?
I wish I had a drain valve in my '67 GlobeTrotter. I need to run the pump and drain it out the city water fitting at the rear of the coach. But then I don't have even half of the original plumbing.
The GT and Safari are nearly identical at the front end so maybe Jim can come back with a little more info.
My sediment filter plugs up every other year or so. The tank was taken out and flushed 7 years ago so appearently enough crud builds up to gum things up.
The last few years I've been using a pre filter on my fill hose when I'm at the campgrounds to see if this helps the situation. I suspect it's just hard water from the camp's well that does it though.
Tom.
Tom Nugler is offline   Reply With Quote
Old 11-06-2006, 03:28 PM   #6
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Prefilters are a great idea, even just the garden hose end insert. You would be amazed at the types of things that we find in the domestic water supply/fire hydrants.
Old 11-10-2006, 11:17 AM   #7
Cracker's Avatar
Pittsfield , Maine
Can anyone tell me how the drain valve is installed on my 2000 30' Excella??? I have the same problem with the valve being clogged and due to the protective tab underneath the valve, it's darn near impossible to blow it out (i.e. - backflush it) with an air hose. The tire and aluminum belly skin prevents me from seeing how the valve is installed and I don't want to start trying to unscrew it only to find out it has a flange with screws. It took a week for the tank to drain this Fall. I know, I know --- I could have drained it with the pump but I just kept waiting!
Cracker
2003 GMC 3500 D/A, CC, LB, 4x4 and 2000 Airstream Excella 30. WBCCI 7074
Cracker is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Help... I Need To Install A Gray Water Tank???? kangol Waste Systems, Tanks & Totes 0 04-19-2004 08:10 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
