I believe that you are likely looking for a plumbing fitting referred to as a drop elbow.
I had been considering what would be needed to re-plumb the water inlet on my Minuet -- had no idea what fitting was needed -- then discovered that it looks just like this fitting that was used in plumbing the shower in my newly remodeled home bathroom.
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC #7864 AIR #827
1964 Overlander International
1978 Argosy Minuet 6.0 Metre
They even have sharkbite one's. Just installed one on mine. you could easily take the old one off w/ a torch, and snap on a sharkbite. Hardest part is drilling new holes, as the "ears" are probably not quite in the same place...but that would be the case w/ any fitting. that part of it doesn't appear to be a "standard".
1979 23' Safari
1954 29' Liner
Orange
Originally Posted by coffeydelsol
Where can we find it?
I found one at Home Depot, try them or Lowes or the local Ace/True Value hardware store or your local plumbing supply store.
Bill
Just my personal opinion
