Old 08-22-2018, 09:38 AM   #1
PORT ALLEN , donantiejr
Need Help to ID plumbing
Guys,
I need some help identifying some plumbing. I have a 1973 International Sovereign 31' Side bath. The plumbing enters on the road side in the corner. I have attached pics of it. I need to ID the plumbing because I want to delete the original regulator as it is leaking and I use a pressure regulator at the water source. I do not use the fresh water tank and as I live in South Louisiana, the system flush/drain for winterizing is really not something we use. I want to delete the old regulator and replace it with a piece of tubing. Can someone give me an idea of what pipe is what? I know which one is the water inlet from outside, but I need to know what to connect to what after I remove the regulator. While I am doing it, I would like to remove the red valve inside (I assume its for the system flush). Hope someone can help. Thanks.
Don
ID:	320551   Click image for larger version
dantiejr is offline   Reply With Quote
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
Need help w/propane plumbing Rmiller51 LP Gas, Piping, Tanks & Regulators 5 11-20-2011 01:09 PM
Need help please with plumbing Ofdtruckie Plumbing - Systems & Fixtures 13 10-11-2011 10:24 AM
Need help with plumbing. netlace Waste Systems, Tanks & Totes 8 11-15-2008 04:15 PM
Need help w/ Re-plumbing sink in '59 18'er Jephellis Plumbing - Systems & Fixtures 2 07-08-2008 08:30 AM
