Old 06-11-2024, 04:55 PM   #1
2017 19' International
Tallahassee , Florida
Need a hose splitter ... how to tell if potable?
I want to use a hose splitter (the Y-shaped thing) where I connect the water hose to the city-water faucet.
But ... how can I tell if the hose splitter is OK for drinking water?
The ones I see are marketed for use in the backyard, to run two lawn sprinklers at the same time.
Anyone have a hose splitter that they know is good for Airstream use?
WhereStream is offline   Reply With Quote
Old 06-11-2024, 05:11 PM   #2
Sioux Falls , South Dakota
I use a brass one. Not cheap, but decent quality, and I'm not worried about it putting something unwanted into my fresh water tank.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 06-11-2024, 05:14 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I can't image the short distance water travels through a splitter would impart a significant amount of anything harmful. Just make sure you water hoses are good for potable water.
2019 Ford Expedition Platinum
Old 06-11-2024, 05:29 PM   #4
hikingcamera's Avatar
2024 25' Trade Wind
Seattle , Washington
If you want to be sure you can order this one from Blutech that is rated as drinking water safe. A bit pricey for my taste (pun intended) especially since I already have one. But does seem like a cool option if I was looking.
hikingcamera is offline   Reply With Quote
Old 06-11-2024, 07:08 PM   #5
Bearstream01's Avatar
2023 25' International
Garden City , New York
OK so, at first i found you this one which specifies drinking water safe https://www.eleyhosereels.com/produc...-hose-splitter
but.... since im curious, i did a little research and found
The NSF/ANSI Standard 61 certification signals that a product is safe to be installed in a potable water system for public use or consumption and is verified by a 3rd party.
Sooooo, anything certified NSF/ANSI 61 should be drinking water safe
https://www.etrailer.com/Water-Shut-.../CAM20123.html
Hope this helps!
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
14457
Bearstream01 is offline   Reply With Quote
Old 06-12-2024, 08:35 AM   #6
Thanks for the recommendation.
Old 06-12-2024, 08:36 AM   #7
Hope this helps!
Very helpful! Many thanks.
Old 06-12-2024, 09:14 AM   #8
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Ok, so what's the "big deal" here?
You do not want to kill folks putting water in your tank. However for a lot of years, nobody really cared much about hoses and "safe". Nobody seemed to die.
If you are simply filling the fresh water tank (so nothing is sitting there for long), it's not at all clear how big a deal any of this is. The contact time is zero. Just flush things before and after use. Away you go.
If you are letting the water sit in the hose for a long while, sure, it's an issue. Hooking up to city water and letting things sit for a couple weeks is a good example of this. Regardless of the hose rating, I'd flush the beast in that situation when I got back to the trailer.
The most obvious risk is a brass alloy that has some lead in it. Compared to lead pipes you don't have much there.
Fun !!
Old 06-12-2024, 09:48 AM   #9
2012 23' FB International
Woodstock , Ontario
SO.... We all use these things to daisy chain at Rallies
Some are brass and some are plastic. None of them come with an ANSI certification.
We usually buy them at an RV dealer. Same stuff as the lawn hose splitters
You are over thinking this!
JCWDCW is offline   Reply With Quote
Old 06-12-2024, 10:14 AM   #10
2024 25' Trade Wind
Where did you live where "nobody seemed to die" and what was your secret to eternal life?
Old 06-12-2024, 12:41 PM   #11
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
Hose splitters are available at just about any hardware outlet, Lowes,Home Depot,etc.
Lowes has pages of choices.https://www.lowes.com/search?searchT...se%20splitters
I stick too metal (not lead).
The most important aspect is the throat size. Especially if you are daisy chaining. There is a different flow rate between 1/2" and 5/8" hose.
cbburke is offline   Reply With Quote
Old 06-12-2024, 02:09 PM   #12
1959 24' Tradewind
Twin Falls , Idaho
Plastic (not painted), Brass or Stainless is fine. You have a filter, right?
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 06-13-2024, 06:00 AM   #13
Half a Rivet Short
2022 Interstate 24X
Hi
Ok, to be more specific, nobody seemed to be killed by drinking from those hoses .....
Old 06-13-2024, 07:59 AM   #14
Mollysdad's Avatar
I use this splitter, but not because of drinking water. I got it because I wanted something that I could attach to the hose barb and use a little leverage so there's no leaks. Then my pressure regulator attaches to that using a quick release.
It's top of the line as far as build quality, the valves are leak free, and work smoothly.
There's so many parts in my hose system it's like a science project. But then, I don't drink tank water.
Growing up we all drank from rubber hoses. Still kicking.
Old 06-16-2024, 09:27 AM   #15
1997 25' Safari
Laurel , Maryland
Ha ha ha
Hope this helps!
If you use it ONLY on potable water, it should be good,,,, ON THE OTHER GAND!
40+ years ago, when us kids played out side and became thirsty, ďgarden hose!Ē What happened to water the last number of years?????
I have a $1 2.97 splitter on the house, and another for the AS. Just donít run contaminated material through it! Creek water, sewage etc!
Rick n Mary is offline   Reply With Quote
Old 06-16-2024, 10:03 AM   #16
Mollysdad's Avatar
I'd worry more about the parts I can't see in the water delivery than in the "Y" splitter I put on the hose barb.
I realize that pure water has been filtered through sand, rocks, limestone, creeks and rain. The amount of water on Earth is constant. Your drinking water has been drunk before, perhaps by an African elephant!.
Name:	Module-4-Lesson-4-Feature-Image-Colorado_Edwards_Filling-Water-Sprinter-Van-7-2.jpg
Old 06-16-2024, 11:50 AM   #17
2020 23' Globetrotter
Hi
Uncle Bob,
I got your point without any fact checking. Whew, Iím in my latter 70ís, and when I think of the things we did growing up, I wonder how fortunate I am to still be around. I canít recall ever seeing an ďorganicĒ sign in the produce section of the local A&P or at the corner grocery store for that fact.
In the summer, while playing outside, we would all run to the garden hose and take a long slurp.
Ah,as the saying goes, penny wise and pound foolish.
Always like your commments and input Bob.
Coopdejour is offline   Reply With Quote
Old 06-16-2024, 02:18 PM   #18
Escape Pod II
John Ware's Avatar
2022 23' Flying Cloud
2018 22' Sport
Orange , Texas
I was starting to wonder if I was the only person on this forum that grew up drinking from a garden hose. Some day they will miss us Baby Boomers.
JEWare
John Ware is offline   Reply With Quote
Old 06-16-2024, 03:30 PM   #19
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
There were a few years where if you wanted a Y splitter for free, simply follow me in the same campsite. It was the only item I seemed to occasionally leave behind. Fortunately for me, my process has improved.
StuartsDad is offline   Reply With Quote
Old 06-16-2024, 07:43 PM   #20
aftermath's Avatar
Spokane , Washington
My Word! Really? If you are going to fill your tank from the garden hose it really isn't going to matter if you have a plastic splitter, a metal one or even a stainless steal one with some phony certificate of "safety" stuck to it. If you are a germaphobe , is it really going to matter? I am 72, I drank directly from a garden hose when I was a kid and I am still alive to tell the story.
aftermath is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
Potable water hose Glamper1 Sprinter and B-van Forum 23 11-19-2014 07:43 AM
Potable Water Hose... manda1215 Fresh Water Systems 32 01-28-2014 08:22 PM
Heated Potable Water Hose? SylviaJane64 Plumbing - Systems & Fixtures 7 09-04-2013 09:53 PM
