I was hooked up at an RV park. Water flowed nicely! Cold snap came so it was unplugged so it wouldn't freeze. All stowed indoors/in truck and did not freeze.
Upon hooking up my Renata regulator read 80 psi so I dialed down to 50 psi and VERY weak at all faucets/ shower head. Cranked up to 60 psi and still crazy low....
Before I go too crazy does this sound like a bad regulator? I unhooked hose from AS and it regulates the steam of water fine. I dialed it to what looked acceptable and still low inside but you can't tell from looking. A few months back I replaced the Shure Flo inlet.
My system is sediment filter ->charcoal -> Renata regulator -> water softener -> AS
Thanks for any advice on where to start trouble shooting!
Here because we have the same issue. We just had a cold snap with a couple of nights below freezing so before it came, as I always do in these situations, I disconnected the hose from the AS and put one of those large-type foam faucet protectors over the inlet, and took our water softener and filter inside the AS.
Today I reconnected and we have very low pressure inside when the pump is off.
A pressure gauge connected directly to the pedestal reads 50psi. Gauge connected to the end of the hose that goes into the AS (after filter + water softener) also reads 50psi.
I don't hear water running inside the AS or see any pouring out of the bottom, so I don't think anything is leaking.
Any ideas on next steps to troubleshoot/fix? Maybe the built-in regulator is stuck/damaged?
