Old 11-27-2023, 09:03 PM   #1
1996 30' Excella
River Falls , WI
Low water pressure on site water
First time out since winterizing this fall
Hooked up to site water
Flushed all faucets then after hot water tank filled the water pressure totally dropped
Toilet works fine
Just very low pressure in kitchen and bathroom faucets
Perplexed
nancys is offline   Reply With Quote
Old 11-27-2023, 09:28 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Toilet is cold water only and the rest are hot and cold. Possible that the hot is the issue? If so, verify the valves on the water heater bypass.
Richard
Old 11-27-2023, 10:30 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Check the aerator screens on each faucet head for debris.
CRH is offline   Reply With Quote
Old 11-28-2023, 06:59 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
Put some water in the freshwater tank and run the pump.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 11-28-2023, 07:13 PM   #5
Boxite's Avatar
2008 22' Safari
And also check the pump screen/filter.
Old 11-28-2023, 08:45 PM   #6
HankO's Avatar
1997 28' Excella
Eden , Utah
low water pressure
Make sure your valves are closed on your low point hot and cold water lines.
HankO is offline   Reply With Quote
Old 12-03-2023, 10:29 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Typically when I leave them open it's pretty obvious ....
Cycling them when you de-winterize is a good idea. Anti-freeze can sit just above the valves and not flush out with the normal "water through the pipes" approach.
On the same "obvious" note: check for a puddle accumulating under the fresh water intake. If the back flow valve cracks, you get a puddle there.
Low Gas Pressure: Low stove flame, hot water heater won’t ignite. tjwoods1 LP Gas, Piping, Tanks & Regulators 16 10-19-2018 03:56 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 02:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 07:29 PM
