Old 04-14-2021, 01:37 AM   #1
Sophomore Year
nunover's Avatar
2010 27' FB International
Mechanicsburg , Pennsylvania
Low Point Drain Valves
I broke one of the low point drain valves on my 2010 Intl CCD 27FB. It looks like this:
I learned this style valve is no longer available and was replaced by Airstream # 602185-01 replaces # 602185 which looks like this:
This valve costs $66. Does anyone know a generic equivalent I can get from a plumbing supply store?
nunover is offline   Reply With Quote
Old 04-14-2021, 02:34 AM   #2
Long Island , New York
Generic ball valves like that are available all over. If you take in a sample of the pipe you need to marry up to, most hardware stores will be able to set you up just fine IMO.
These "replace low point drain site:airforums.com" search results reveal similar threads here:
https://www.google.com/search?q=repl...=airforums.com
Good luck.
Peter
Let the music lift you up . . .
Old 04-15-2021, 12:44 AM   #3
Sophomore Year
nunover's Avatar
Thanks OTRA15
? about 2 low point drain valves on '09 International 25FB... Opn Rd 2006 - 2010 International 3 02-13-2019 05:58 PM
Low Point Water Line Drain Valves Froze! Dwellstream Fresh Water Systems 25 11-21-2014 11:10 AM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
Low point drain valves Gringo Fresh Water Systems 4 11-03-2011 09:13 AM
Replacing the low point water drain valves thecatsandi Fresh Water Systems 4 02-17-2009 11:32 AM
