Old 11-26-2019, 08:02 PM   #1
2016 26' Flying Cloud
Wherever , Texas
Low hot water flow
Just filled fresh water tank getting ready for week long trip and I get very low flow when hot water is on. It happens in kitchen, bath and shower. The pump sounds fine on cold water but it responds more slowly when hot water is turned on. Like there is a delay in sensing need for pump. I made sure that all air was out of lines and water heater. Made sure bypass valve is open. No visible kinks in hot water lines. We are usually on FHU.
Any ideas appreciated.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 11-26-2019, 10:11 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Recent thread here could be valuable.
http://www.airforums.com/forums/f540...er-203206.html
rowiebowie is offline   Reply With Quote
Old 11-27-2019, 08:24 AM   #3
Wherever , Texas
We get hot water in sink, bath and shower, just low volume. Cold water is normal.
Equalizer Hitch
Old 11-27-2019, 09:50 AM   #4
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
I had exactly the same problem earlier in the year after winterizing. Cold was fine, but hot was a trickle. My particular problem was at the mixing valve of the hot water heater. The mixing valve itself was fine, but there was a spring that had come unseated causing the hot water flow to be restricted. After repositioning the spring, everything started working again. Here is a link to the thread that shows pictures of my problem.
http://www.airforums.com/forums/show...errerid=103283
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 11-27-2019, 10:02 AM   #5
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Do you have a tempering valve? commonly called a mixing valve as well.
Google found this:
http://www.airforums.com/forums/f445...ve-177432.html
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 11-28-2019, 09:35 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Interesting - not had this happen yet - wonder if there is hard water deposit in the lines???
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 11-28-2019, 09:50 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Well it's a restriction.... I guess we all know that, the trick is going to be finding it.
Is there a valve somewhere that isn't obvious?
Old 11-28-2019, 09:58 AM   #8
2015 20' Flying Cloud
Lander , Wyoming
For a long time I thought the problem was a stuck temperature mixing valve. However, I finally determined that air gets trapped in the piping near the hot water heater, which then restricts the flow of hot water to all the faucets. If you open the dump valve on the hot water piping that’s under the water heater with the pump on (or city water hooked up), you can blow the trapped air out of the piping. Then close the dump valve and you should get good hot water pressure at the faucets.
Wetfeet is offline   Reply With Quote
Low Gas Pressure: Low stove flame, hot water heater won’t ignite. tjwoods1 LP Gas, Piping, Tanks & Regulators 16 10-19-2018 02:56 PM
low hot water pressure/flow Titus Sprinter and B-van Forum 14 05-11-2018 03:09 PM
Low flow of hot water in bath sink? jholder General Repair Forum 0 02-25-2017 08:13 PM
Low Hot Water Flow 762x51 Water Heaters, Filters & Pumps 31 04-25-2016 04:49 PM
Low water flow in Thetford toilet kds Sinks, Showers & Toilets 1 09-19-2015 08:52 PM
