Old 11-04-2018, 04:16 PM   #1
2008 16' International
Aptos , California
Insulating pex pipes
I have a 2008 16 ft bambi, and if the outside temp drops to under 24 degrees while camping my water line freezes at night. I run the installed heater on low and open the kitchen cabinet, but much of the line runs along the outer skin under the fridge and in a front compartment that doesn't receive any heat. So far the pipes have not been damaged, and I can get them working again with 5 minutes with a hair dryer. I'd like to prevent it from happening at all. Does anyone have experience with trying to insulate their inside pipes in critical areas, or installing heat tape on them?
Spitshotz is offline   Reply With Quote
Old 11-04-2018, 04:20 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have heard pex is not as prone to freeze damage as other types, but I would like to hear from someone who knows for sure.
Old 11-04-2018, 04:41 PM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
The pex itself expands and contracts back, One method of assembly is using an expanding tool that does just that so you can install over the fitting.
That said the fitings Im not so sure they can withstand the freeze along with any valves and pumps.
You can go to the big box and buy pipe insulation that is pre slit with sticky tape and the only obstacle being access.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 11-04-2018, 05:19 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
PEX and modern PEX fittings should not be damaged by freezing. Putting insulation on them does work, but it does not help a lot. If it stays cold long enough, the insulation will not do any good. Also if it gets cold enough .... same problem.
One alternative is to put heater strips on the pipe and then put insulation over that combo. Then whenever it gets cold, you turn on the heaters. The main trick is to be sure you don't get any hot spots that melt the pipe ....
Pex or not to Pex? Isuzusweet Fresh Water Systems 32 09-14-2019 11:21 PM
Pex or not to Pex ? Thomasmg Fresh Water Systems 28 03-19-2016 03:05 PM
To PEX or not To PEX perryg114 Sinks, Showers & Toilets 69 10-04-2012 04:32 PM
