I have a 2023 FC RBT and can't find the T valve that is supposed to drain the fresh tank. Does my trailer have one? Does the fresh tank only drain from the low point valves? Thanks in advance.
My owner's manual didn't specifically say where the fresh tank drain is located. My low point drains are where you described, so I guess that may do. Thanks for replying to my question!
That fresh water drain valve can be hard to reach. I have always just turned on the pump and run the water out of the fresh tank using the outside shower.
Brian
__________________ SuEllyn & Brian McCabe WBCCI #3628 -- AIR #14872 -- TAC #FL-7 2015 FC 25' FB (Lucy) with ProPride 2020 Silverado 2500 (Vivian)
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
On our 2023 International the fresh water drain is on the side of the tank and BEHIND a tire. I had to get on my stomach and put my head between the tires to find it. Ours is on the passenger side.
It's not a location that convenient to find or reach.
