Old 04-21-2021, 10:47 PM   #1
1968 26' Overlander
San Francisco , California
freshwater tank for 1968 Overlander
Hi all,
I just bought a used 30 (maybe 31) gallon freshwater tank from RV Depot over in Yucca Valley CA. Dimensions-wise, it fits, but the inlet on the tank doesn't line up w/ the fresh water fill. Wondering if that's typical? Or can I use flexible hose to "make it work", or should I just get a different tank altogether? FWIW, the old tank came from a Caravelle.
Strangely, the fresh water fill port affixed to the airstream seems unnecessarily close to the flooring. Please see attached pics.
ID:	393814   Click image for larger version
ID:	393816   Click image for larger version
wangissimo is offline   Reply With Quote
Old 04-22-2021, 11:37 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I agree that the fill point is unusually low. The image below is from my '67 Overlander.
Although a flex line could work, I will mention that my tank is usually filled from the city water line. The exception is winterizing & de-winterizing when anti-freeze or bleach water is added. If I was in your situation I would consider adding those two items from the inside.
Of note, the tank needs venting for both filling & emptying - a job usually handled okay by the exterior fill.
Tom
Old 04-22-2021, 02:02 PM   #3
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
Possibly...
One can never speak of airstreams in absolutes, but...
If the salon of your trailer is "Double" it will have a low, flat tank under the front gaucho.
If the salon of your trailer is a "Twin" it will have a tall, narrow tank against the front wall, between the dinette seats.
You have a new "Twin" configured tank, that will not accommodate a "Double" configured salon.
You need the flat tank to solve your problem neatly.
If the third to last digit of your serial number is 5 or greater, your trailer is a "Double", and was designed with a low fill-neck for a flat tank.
ID:	393890   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 04-22-2021, 04:18 PM   #4
NO HUMBLE OPINION
oops,
So if you look at the archive images,
https://www.airstream.com/wp-content...ations-231.pdf
Turns out that all 1968 Overlanders may have had the low tank, and the tall tank you have is for a 1968 TradeWind "Twin" or Safari "Twin".
A front gaucho won't fit over the tall tank.
Old 04-23-2021, 10:36 AM   #5
1968 26' Overlander
2021 20' Caravel
Denver , Colorado
I bought one years ago for a 1968 Overlander from vintage trailer supply. They had a full selection by year and model. https://vintagetrailersupply.com/int...holding-tanks/
englishw is offline   Reply With Quote
Old 04-23-2021, 10:37 AM   #6
1968 26' Overlander
Thanks all! Looks like I have the double. Won't matter to me if a gaucho won't work - all that had been torn out earlier anyway. And I plan on building a custom couch/bed area anyway.
Currently, the tank dimensions are 11"x11"x54", with its inlet opening at 12.5", which is about 5" above the bottom end of the external water inlet port. A flex line would work, but wondering if I should get the right tank for the cleanest solution, like https://vintagetrailersupply.com/53-...8-71-vts-1004/ . This way I won't have to figure out some pressurized way to get municipal water through a serpentine hose.
Old 04-23-2021, 12:46 PM   #7
NO HUMBLE OPINION
relocate/patch
Aside from aesthetics and originality, no reason not to drill out fill-neck rivets and relocate to suit tall tank. Olympic rivets, and you choose shape of patch.
https://www.airforums.com/forums/f38...hes-68104.html
Old 04-23-2021, 02:42 PM   #8
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Faced the same thing when redoing my '68 Overlander, trailer had nothing in front when I got it. I went with the 12x12x54 from VTS and they put fittings where I wanted. I was going for max storage under what is a twin xl pullout to 50x80 bed. 3 giant drawers under bed. I decided to go with fill and vent inlets on top of the tank, others have put them on the side, I liked top for less chance of leaks. Mocked it all up and decided where to put the fill, probably 12" higher. You can see the fill is over the top of the tank so the tank stays centered. With a 6" foam mattress the bed is maybe 1' too high at 21" but I'm 6'. Outlet and drain are SS as low as possible, vent pipes down to drain hose.
Good luck, Mark D
ID:	393950   Click image for larger version
mrdes8 is offline   Reply With Quote
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
Freshwater tank leaking - can it be repaired? drboyd Fresh Water Systems 3 09-13-2003 10:03 PM
Overflow hose in freshwater tank is loose. TBKP's Overlander Fresh Water Systems 1 08-03-2003 08:46 PM
