Old 02-05-2022, 08:12 AM   #1
Mcwey's Avatar
2018 30' Classic
Fort Collins , Colorado
Images: 8
Freshwater tank filling on it's own?
We have a 2018 Classic and are parked with shore water on.
When we left home the freshwater tank was at 35%.
Yesterday (after 3 weeks parked) i noticed the tank
was at 90%? Not sure how this could happen?
Any suggestions?
Monty
Mcwey is offline   Reply With Quote
Old 02-05-2022, 08:16 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
Water pressure from the city water hookup pushes past the on board pump and slowly fills up the on board freshwater tank. There could be a weak seal in the pump, or a piece of grit stuck in the pump seal that allows the water to seep backwards past the pump and in to the freshwater tank.
First thing I'd recommend is unhook city water inlet and use the on board pump for a day or two. Some times this will rectify the situation.
Then hook up the city water again in a couple days and monitor the freshwater tank to see if it's been resolved.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 02-05-2022, 08:19 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Both the shore water and the fresh water tank hook to the same pipes in the trailer. There are "back flow" valves that stop the water pump from pushing water out the shore water input. There also is a valve that should prevent the shore water from backing up into the fresh water tank.
Both of these valves can get crud in them. Both can leak as a result. The valve on the shore water input can easily have freeze damage. In your case, the quick fix is to run the water pump for a bit. This usually clears any crud. It might be worthwhile to clear the strainer before you do this.
Old 02-06-2022, 07:13 AM   #4
Mcwey's Avatar
2018 30' Classic
Images: 8
Two great answers! Thanks so much I will
Give it a try!
Monty
Old 02-06-2022, 10:06 AM   #5
Razorhog's Avatar
1974 27' Overlander
2015 28' International
Little Rock , Arkansas
I'm guessing the strainer is on the water pump. How do you get to it?
Razorhog is offline   Reply With Quote
Old 02-06-2022, 11:23 AM   #6
2015 30' Classic
Topsham , Maine
We snow bird in Tucson and the water has its share of mineral deposits. Going from pump operation to shore and back occasionally resulted in the tank filling at random times. We leave the fill door open just in case. A couple of times the fresh water tank has overflowed through the vent.
We do cycle the pump a few times to clear the check valve seat on the pump and that seems to work. For a while.
If we have no need for onboard water we can leave the tank drain open. Either way works to prevent tank over pressurization and damage.
2spinnerz is offline   Reply With Quote
Old 02-06-2022, 11:51 AM   #7
Gulliver72's Avatar
2015 25' FB Flying Cloud
Barnstable , Massachusetts
Just a little suggestion beyond all the above. I wouldn’t leave the city water on when not occupying the trailer. A pipe could easily burst, and you would be in for a very bad day when you returned. Just saying!
Gulliver72 is offline   Reply With Quote
Old 02-06-2022, 03:05 PM   #8
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Ditto #7. Also , use a Camco Blue filter on the city water line and also when you manually fill the fresh water tank. I have done that on two trailers with no back fill problems for 30 years.
guskmg
Old 02-07-2022, 07:51 AM   #9
Half a Rivet Short
2022 Interstate 24X
Hi
When you dive in to winterize your trailer, you will find the water pump mounted in some odd place. Attached to the input to the pump / part of the pump is a little strainer gizmo. You dump them once a year as part of the winterize process. ... hmmm .... don't winterize you say? Still need to clear the strainer once a year.
Old 02-07-2022, 09:36 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
When our trailer was brand new we had this happen to us. Dealer said it was a bad check valve in the pump which allowed city water to flow into the holding tank. The pump was replaced under warranty and all was well.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 02-08-2022, 05:44 PM   #11
K4TCJ
K4TCJ's Avatar
2009 27' FB Flying Cloud
Crestview , Florida
Mine did that when hooked to city water. It was the check valve mounted on the very front of the pump. A very easy repair.
K4TCJ is offline   Reply With Quote
Old 02-08-2022, 05:55 PM   #12
StuartsDad's Avatar
2018 28' Flying Cloud
Chapin , South Carolina
Our did same when new. Running pump corrected for a couple of years. Last fall it started slowly leaking by again. Bought just the check valve and replaced. No problem since. I remember the valve being just over $20. We do try to remember to turn city water off when leaving for any extended period.
StuartsDad is offline   Reply With Quote
Old 02-13-2022, 05:24 PM   #13
2016 25' Flying Cloud
Houston , Texas
The pump has a check valve built in. It is common that they fail or leak allowing city water to fill the fresh tank. Sometimes you can stop a leak by running pump to clear crud that causes a leak in check valve. I kept having the problem and simply installed an additional brass check valve. It’s a cheap fix, parts available at hardware or plumbing store.
robearl733 is offline   Reply With Quote
Old 02-14-2022, 07:09 AM   #14
DMBValP's Avatar
2006 16' International CCD
Valparaiso , Florida
I had the same problem and needed to replace flap valve on water pump . That fixed it.
DMBValP is offline   Reply With Quote
Old 02-14-2022, 10:00 AM   #15
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
You can just buy one of these:
https://www.amazon.com/Camco-23303-B...%2C158&sr=8-42
... and put it on the inlet side of the pump. Fixed forever and it took ten minutes (assuming you can find the pump!).
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 02-14-2022, 10:46 AM   #16
eagletoo's Avatar
New Hyde Park , New York
Great suggestion, Rob. Does backflow valve install take place before the strainer or after? Does it matter? Thanks
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 02-14-2022, 02:52 PM   #17
RFP
RFP's Avatar
Hurst , Texas
Doesn't matter a bit... just put it wherever it's easier to get to. I installed one of these even with NO issue with the pump's built-in check valve. I like to proactively do whatever I can to prevent bad stuff - or even nuisance stuff - from happening.
Rob
And some stuff
Old 02-14-2022, 03:09 PM   #18
RFP
RFP's Avatar
Hurst , Texas
Rob
And some stuff
Old 04-26-2023, 11:24 PM   #19
Seattle , Washington
Digging up an old thread here.
We found our fresh tank filling while on city water and I'd like to install the check valve.
I see the shurflo pump in our AS has NPSM threads on the inlet and outlet. This valve is NPT threads.
Have you had any problems with the check valve threading onto the water pump?
DaHealey is offline   Reply With Quote
Old 04-27-2023, 08:01 AM   #20
"Cloudsplitter"
We never have the "shore" water hooked up, consequently the pump one way has never failed.
POI we fill the tank when needed without worry.
This is the reason...at 3am it poofed, cross threaded at the factory, repaired on the road with MarineTex 13 yrs ago.
ID:	430768   Click image for larger version
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
filling freshwater from shore fitting Greg1410 Fresh Water Systems 15 03-12-2016 10:53 PM
Own your own scale? Ag&Au Jacks, Stabilizers, Lifting and Leveling 8 01-26-2014 02:52 PM
1974 Airstream Sovereign filling freshwater tank texasbound Fresh Water Systems 19 04-19-2013 11:14 PM
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
