Old 10-01-2024, 03:05 PM   #1
camden , maine
Freshwater tank drain
I’m winterizing right now
2005 Safari 25
I have Three drains under the water tank in between the curbside wheels
Two are metal petcocks these seem to be system drains and drain well with the water pump running
The third is a white plastic/pvc valve which I think is the direct tank drain , very difficult to shift the lever
I get nothing out when I operate this one
Is it gummed up through never being used?
Is there another direct drain?
I have emptied the tank now through the system drains by using the pump until it ran dry
I will now blow through with 50 psi compressed air through the city water connector and then think about how best to get anti freeze in
Anyone have any thoughts
Help much appreciated
My first Airstream so my first rodeo
Thanks all round
wagontrain is offline   Reply With Quote
Old 10-01-2024, 05:11 PM   #2
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
That white valve is the fresh water tank drain. They are sometimes hard to open, and I have used food grade silicone spray up and into the valve to help keep if moving. If you have drained the tank with the pump, there is virtually nothing left in the tank Get an antifreeze winterizing kit and install the valve on the INLET side of the pump. Then use the pump to pump antifreeze through the system.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,
1994 Excella 34' 1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 10-01-2024, 05:21 PM   #3
camden , maine
Thanks CB
That makes sense
Antifreeze will come out of the faucets and the shower head will it be sufficient to fill the traps in the sink drains?
Does the shower tray have a drain trap before it goes into the grey tank?
Anything special around the toilet that needs special antifreeze attention?
Old 10-01-2024, 06:52 PM   #4
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
I always pour some extra into the sink drains, after I use a toilet plunger to purge the water out of the trap. Yes, there is a trap under the shower. Don't forget to run anti freeze through the toilet and the rinse spray as well. Remove the filter for the drinking water tap on the kitchen sink and install the bypass if you have one. Don't be afraid to use extra Antifreeze, it's a lot cheaper than plumbing repairs. I usually leave the drain out of the water heater as well. Don't forget to bypass the water heater before putting anti freeze in the lines.
ACI #7394
Hensley Hitch
Old 10-07-2024, 10:17 AM   #5
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I am having the same issue. I know they are to open however even when I got it mostly open no water came out. Is it a bad assumption on my part to assume it is clogged. If so what is the best way to un clog it?
urnmor is offline   Reply With Quote
Old 10-07-2024, 02:59 PM   #6
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
The freshwater tank is wide and shallow. If your trailer is tipped at all to the curb side, there will be water left in it, out of reach of the pump and the drain line.
I drain my fresh tank using the little white plastic drain while I am parked in front of my house. Then I drive to my storage lot dump station. I pull onto plastic blocks there, and get several more gallons out of my fresh tank.
SSquared is offline   Reply With Quote
Old 10-07-2024, 03:23 PM   #7
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
You can blow air up into the valve, but low pressure. As long as there is no water in the valve the small amount in the tank can freeze and do no harm.
ACI #7394
Hensley Hitch
Is this my Freshwater Tank Drain? Rich Jenkins Fresh Water Systems 51 12-23-2022 03:48 PM
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
Freshwater Tank drain crazeevw Classic Motorhomes 9 10-28-2011 08:16 PM
Freshwater tank drain plug on 08 23FB? bonginator Fresh Water Systems 1 09-06-2010 08:03 PM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
