Old 04-20-2024, 02:41 PM   #1
2018 30' International
haymarket , Virginia
Freshwater Dropping, Blackwater Filling
Thanks in advance for any insights on this one.
2018 International 30RB.
It sat for a week with Freshwater @ 100, both tanks at 0.
Hooked to electrical power but no external water, pump was in the "on" position.
After a week, Freshwater is at 70. Blackwater at 38. Grey water still at 0.
The gauges are correct. Freshwater was low (added to fill back up) and blackwater had water it in (straight fresh water, no waste).
No visible leaks in the unit inside or out.
How is the freshwater getting into the blackwater tank?
davesturner is offline   Reply With Quote
Old 04-20-2024, 03:27 PM   #2
diesel maniac
ITSNO60's Avatar
Airstream - Other
Tucson , AZ
Many times the bathroom sink will be plumbed to the black tank and if your bathroom sink faucet leaks this would gradually fill the black tank. If this is the case you will notice your pump running very briefly every so often.
Brian
ITSNO60 is offline   Reply With Quote
Old 04-20-2024, 05:44 PM   #3
Thanks! I will definitely check that out....and I do believe there is a slow drip from the vanity sink. Another repair on the list.
Freshwater tank filling on it's own? Mcwey Fresh Water Systems 21 04-27-2023 04:27 PM
filling freshwater from shore fitting Greg1410 Fresh Water Systems 15 03-12-2016 10:53 PM
Blackwater tank filling when not being used recharge Plumbing - Systems & Fixtures 13 01-26-2015 05:31 AM
1974 Airstream Sovereign filling freshwater tank texasbound Fresh Water Systems 19 04-19-2013 11:14 PM
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
