01-01-2021, 03:58 AM
2021 Interstate 24GL
Los Angeles
Fresh water tank sensor bad? shows empty but tank is full
we just left for a trip and arrived at our destination.
I filled up the fresh water tank full at home, the monitor shows 100%. but half way through when we stopped for fuel, the tank shows empty. I drove some more and it's back again at proper level. it just goes between full and empty.
maybe a loose connection ? or cold weather?
it's about 15F outside now. tank heater is on
01-01-2021, 04:44 AM
2018 25' International
Slidell
, Louisiana
Yes a loose connection. Perhaps on the panel or where the sensor is spliced in or in the wire run between them. The panel is not too hard to look at. The rest involve getting access to the fresh tank. Some models have access through the floor under the street side cabinets. You might check the panel, if its not that consider having it repaired under warranty. Your call.
01-01-2021, 11:21 AM
Los Angeles
It seems to be fine again during the day. Definitely something to do with the cold I guess. Maybe on the outside.
Another problem, the water heater stopped working. It says “fault, cycle & clear”
01-01-2021, 11:27 AM
Slidell
, Louisiana
I'm not familiar with the Interstates too much, what is the heater model? I'd cycle power and see if the fault clears. probably have to shut of both 12V and 120V. With the model I can go find a service manual.
01-01-2021, 11:56 AM
Los Angeles
I’m trying to find out the model too but it’s not in the manual. It says “6 gallon with elec element” in the parts list. It says “suburban” on the outside of the van
01-01-2021, 12:17 PM
Los Angeles
I’m pretty sure it’s the Suburban IW60 on demand
The owners manual is way outdated
01-01-2021, 03:30 PM
Slidell
, Louisiana
So if it is the gas only tankless IW60, I'm confused cuz the service manual indicate fault codes E0-E9 but no text fault descriptions.
01-01-2021, 05:40 PM
Los Angeles
There’s no fault code display on the c zone panel. It’s triggered by a wire from the heater and tells the c zone it has an error
For actual error code you have to look at the heater
I didn’t bring any tools with me this time. I guess I’ll live with ice cold water for now
01-01-2021, 06:21 PM
Slidell
, Louisiana
If it is an IW60 there is a manual reset button on the ECO switch inside the left panel near the upper right.
01-01-2021, 08:20 PM
Los Angeles
you mean the access panel at the water heater right? it requires a screw driver and it's under the bed... i guess i'll have to do it when i get home.
01-02-2021, 06:55 AM
Slidell
, Louisiana
Yes, how unfortunate.
01-02-2021, 11:45 AM
Los Angeles
It somehow magically reset itself and it’s working again.
01-02-2021, 07:21 PM
Slidell
, Louisiana
Lucky You!
