Old 02-05-2023, 03:02 PM   #1
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
Angry Fresh Water Tank R & R
I have an 2009 25FB Classic that the fresh water tank is leaking and in need of replacement along with the pan. Any one has done this and could pass on any short cuts or don't do this, but do this. Thanks
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 02-06-2023, 10:28 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Are you sure it is the tank. I had a leak on my 2002 Safari which was the line from the tank to the drain. Airstream of Chandler replaced the $10 line with 2 hours of labor. They cut an access hole in the pan to get to replace the hose.
Richard
Old 02-06-2023, 11:23 AM   #3
1993 21' Sovereign
Bryan , Texas
Drain plug for fresh water tank
I have a 1993 21’ Sovereign. I was flushing all my lines and noticed water draining from the pan under the fresh water tank. When I opened the access panel I saw that the drain plug seems to have shrunk such that water is draining around it. The treads are full of Teflon and it still can be pulled out by hand. I have never seen anything like this before. Does anyone know the correct size for this plug and where I can purchase a replacement? Thanks, David
wdc1369 is offline   Reply With Quote
Old 02-08-2023, 07:22 AM   #4
Julie-Bob's Avatar
2009 25' FB Classic
Yes the tank is leaking, I need to replace it cracked beyond repair. I have a new tank and pan on order from Mother Ship. Looking like I will need to rise the trailer up on a ramp so the tank/pan will clear the rear axle. Has anyone replaced their tank? Any words of wisdom for me? I live in AZ and taking Jetstreamer to Mother Ship is out of question.
Old 02-08-2023, 07:32 AM   #5
Julie-Bob's Avatar
2009 25' FB Classic
Per my parts book if you have a 54.5 gal tank as mind does its a 1 1/2 plug, part number in book is 600155 call Woodland RV 616-363-9038 parts ext 103 they will help you.
Old 02-25-2023, 09:56 AM   #6
Julie-Bob's Avatar
2009 25' FB Classic
I changed out my fresh water tank. Here are photos for you reviews. I put the trailer up on 2 ea 2x8x5' on top of 2 ea yellow pads. We had lots of room to lay under the pan and drop the assy. You can see I cut the fresh water pick up line and installed a shark bit fitting, I disconnected the fill line at the fill panel and then installed the line on the new tank and feed it up. After I installed the tank I found that you could reach the fill line on top of the tank before removing the tank. In the phots I show the low point drains and the cut out under the shower, also the ramp that I used to lift the trailer.
Old 02-25-2023, 03:39 PM   #7
Julie-Bob's Avatar
2009 25' FB Classic
Originally Posted by julie-bob View Post
i changed out my fresh water tank. Here are photos for you reviews. I put the trailer up on 2 ea 2x8x5' on top of 2 ea yellow pads. We had lots of room to lay under the pan and drop the assy. You can see i cut the fresh water pick up line and installed a shark bit fitting, i disconnected the fill line at the fill panel and then installed the line on the new tank and feed it up. After i installed the tank i found that you could reach the fill line on top of the tank before removing the tank. In the phots i show the low point drains and the cut out under the shower, also the ramp that i used to lift the trailer.
[attach]428546[attach]428547[attach]428548[attach]428549[attach]428550[attach]428551[attach]428552
ID:	428546   Click image for larger version
ID:	428548   Click image for larger version
ID:	428550   Click image for larger version
Filling fresh water tank 2019 airstream fresh water fill problem arvaterry General Repair Forum 7 06-01-2022 08:44 PM
Used fresh water, gray water, & black water tanks for sale Gladys15 Airstream Classifieds 0 10-31-2019 01:55 PM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
