Old 02-06-2024, 10:40 AM   #1
2017 30' International
Los Angeles , California
Fresh Water Tank Mysteriously Refilling Post-Sanitation
Yesterday I completed my first routine sanitization of the fresh water system in my "fairly new-to-me" '17 International Serenity 30RB. The whole process went splendidly, or so I thought until I woke up this morning to find the street-side fresh water tank input leaking water everywhere and the ground very wet. Mysterious! I'm hoping I just missed a step. Here are the details.
To start, I haven't yet had the occasion to actually use the fresh water tank. Since I bought the AS, the tank monitor has read a steady 15% for fresh water. The water pump works, but I leave it off since I use city water daily from a spigot.
I followed the fresh water sanitization process, and to end, I refilled the fresh water tank back to 15% with filtered water, turned off the water pump, reattached the spigot to the curb-side water input, turned the spigot on, cleared the system, and went to bed. At that point, the monitor read 15% for the fresh water tank, and both the gray-water tank and black water tanks were zero, since also I dumped them yesterday.
When I woke up this morning to find water all over the ground and water (gently, at that point) gushing out of the street-side fresh-water input, I went inside and checked the monitor. The water pump was off, how I left it. But the monitor read 100% for the fresh water tank. (And, oddly, the black-water tank was also higher than I left it the previous night). How could that be? I wondered, is there any way for fresh water to get in the fresh water tank without me putting it there? I have been using city water from the spigot for the last six months without issue; this is the first time anything like this has occurred. Wait, there's more.
I turned off the spigot. I dumped the fresh water tank, as I had done twice the day before as part of the sanitization process. After that, again, the monitor read 0% for all three tanks. I did not put any water back in the fresh-water tank. The water pump was off. I then turned on the spigot connected to the curb-side input and cleared the lines briefly using the kitchen faucet. Here we go.
With NO water running, and me just sitting here, I watched the reading on the fresh-water monitor start to creep up. The fresh water tank suddenly read 5% in about 5 minutes, then 10%, then 15%. I noticed the black-water tank read 6%. I turned the spigot off. What in the world?! I promise: I put nothing in the fresh water tank using the street side water input.
Thank you for sharing your thoughts and advice. Much appreciated!
Dsapp1 is offline   Reply With Quote
Old 02-06-2024, 11:50 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
Your on board water pump has a backflow preventer in it. That has either failed, or is stuck open.
Turn off or disconnect the city water, and run the pump for a spell, maybe an hour, maybe a day or two.
Then turn the pump off, and reconnect the city water, and watch the freshwater tank reading to see what happens.
This is actually not uncommon, and several threads on here discuss the issue.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 02-06-2024, 01:05 PM   #3
@majorairhead. Thanks for the response. I've turned off the city water, turned on the water pump, and will recheck later. Meanwhile, I'll search for the other threads you mentioned. Thanks again. Fingers crossed.
Old 02-07-2024, 05:55 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Here's a good search link for google: water filling on its own site:airforums.com
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 02-07-2024, 07:23 AM   #5
Mollysdad's Avatar
None of the usual tricks to unclog the back flow valve worked.
I replaced the pump with a new unit.
I always wanted a spare anyway, right?
Old 02-07-2024, 10:04 AM   #6
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Indeed, pumps are pretty cheap / easy to get. Installing a new one is a bit fun, but it's just bashing your knuckles here and there. It should be a DIY compatible project.
While you are at it, take a look and see if you have a winterize / anti-freeze feed setup on the input to the pump. If not, it's a fine time to install one.
Old 02-08-2024, 07:02 AM   #7
2017 25' Flying Cloud
Woodway , Texas
Shurflo Pump Problems
Our Shurflo pump also started dumping water into the fresh water tank when hooked up to city water. Since you've kept your old one as a backup, you might go ahead and replace the check valve which will solve this problem. Kits run about $12 - $23 and it's about a 15-minute job once you have the pump out of your AS.
The instruction sheet covers all parts of your pump as well so it's a good source for any disassembly you might want to do in the future.
emelaich01 is offline   Reply With Quote
Old 02-12-2024, 06:09 AM   #8
JBTeton
JBTeton's Avatar
2017 27' Flying Cloud
Boulder , CO
I put in a new kit to try to solve this problem and then replaced the whole pump but neither one fixed the problem. Ended up putting in a ball valve in the line from the pump to the freshwater tank (easy mod if you have the tools). I have to remember to open it up when we are boondocking but it is a very definitive way to solve this problem.
JBTeton is offline   Reply With Quote
Old 04-25-2024, 04:35 PM   #9
2016 23' Flying Cloud
ROCK HILL , South Carolina
Your problem sound framiliar to my experience. Preparing for a recent camping trip we hooked up the water from the house tap and was surprised to hear the water filling the black tank. Nothing would come out of the AS taps. It filled up to 100% as I tried various fixes to remedy. Went to the forums but no real solution.
I filled the fresh tank and used it with the pump while on our short vacation in Nashville. Used the camp shower and toilet.
After a conversation with a parts mgr at a AS dealer, he brought up one of his techs to join in. I was surprised they didn’t give me the usual “ we’ll bring it in” reply. The tech said, change out the pump as the reverse flow diaphram can blow out from too much inlet pressure in the camp ground or from your house tap.
$130 pump from the RV store Same brand as the AS OEM. OMG WHAT A PAIN REMOVING THE OLD AND INSTALLING THE NEW. 4 screws, two water inlet thread and 2 wires should not be difficult. All the way back next to the side wall and no way to access it without a big reach lying on the floor. AS designers are evil or just never had to fix anything on their systems.
20TIRES is offline   Reply With Quote
Old 04-25-2024, 04:55 PM   #10
19í Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
After a conversation with a parts mgr at a AS dealer, he brought up one of his techs to join in. I was surprised they didnít give me the usual ď weíll bring it inĒ reply. The tech said, change out the pump as the reverse flow diaphram can blow out from too much inlet pressure in the camp ground or from your house tap.
Are you absolutely certain that you didnít connect the city water hose to the blackwater tank flush port? It is often in close proximity to the city water inlet port.
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Fresh water tank is filling mysteriously PamK53 2018 - Current Globetrotter 7 05-13-2020 01:43 PM
Refilling propane tank sciggy87 Base Camp 5 04-24-2019 02:37 PM
LP tank removal for refilling DeltaRon 2016 - Current Classic (all lengths) 11 07-16-2018 07:15 AM
RV Site Sanitation ITSNO60 On The Road... 28 05-16-2018 04:51 AM
LED Lights Mysteriously Stopped Working LiLNomad Lights - Interior & Exterior 3 10-28-2012 02:16 PM
